Browsing this Thread:   3 Anonymous Users
« 1 ... 22 23 24 (25) 26 27 28 ... 42 »
Re: Project Drift coupe (AKA 1200 coupe )
From mandurah
im using flipped springs with an extra leaf in each pack ,but i have now got a set of adjustable coilovers for $50 and they look to be pretty good so ill put them in the rear and probably chop the floor out then mount them to my cage (when i make one :D)
but yea i know itts not going to be easy but it should be abit of fun haha
so axel tramp was the main problem ? did it try to spin at all ,and how twitchy was it ??? what motor ?? front end ?? i need to know as much as possible :D
thanks for the kind comment guys ,i dont think much of the car yet ,but its getting there
Posted on: 2011/1/10 15:03
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From perth
wheres the big intercooler jesse?
was it too big to fit?
Posted on: 2011/1/11 11:28
From perth
caltracs will cure any tramp
you have drawings there jesse
Posted on: 2011/1/11 11:29
From mandurah
yep i had it mounted but i figured out that if i hit the dirt it would probably get ripped of the front or the pipes would get pulled of and the motor would suck in a heap of dirt :S so instead im using the more compact one jordy gave me and it sits snug behind the grille
plus the big one would of been realy laggy compared to the small one ,but ill see i might change things around later :D
Posted on: 2011/1/11 13:35
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From perth airport
got a pic of the big one ?
Posted on: 2011/1/11 22:07
perth airport parking
Datsun 1200 ute A14
From Mandurah, Western Australia
intercooler bends
Jesse, this guy does a range of intercooler bends in different sizes etc and cheaper than local guy. If get stuck you can pay me and I will order.
Posted on: 2011/1/12 12:28
From Perth WA AUS
You'll need to do some serious work to mod this style of cage to mount coilovers to it:
jpg  Rollcage2.JPG (69.81 KB)
9665_4d2da19613a07.jpg 581X778 px
Posted on: 2011/1/12 12:42
Datsun 1200 2Dr sedan.
From mandurah
yhea it would work nigel just need to cut the floor and then weld some brackets onto the horizontal brace :D
they are fairly long so it would probaly work
but i see what you mean its abit high isnt it
thanks jarrad ,i might get them through you cos they are $70 a bend from sikem wrex
Posted on: 2011/1/12 14:43
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Adelaide, SA
na it spun up really well, but the crappy shocks didnt like it and didnt last long. Im running all maddat front end, with ca fairly stock. It was alot of fun but i think it would be best to make the rear really stiff. My car just wants to take off, doesnt really kick out and slide, if that makes sense. Really had to throw it.
Posted on: 2011/1/13 10:25
From mandurah
haha awsome to hear ,i am just aboit ready to drive it ,ive put a standard rebuild set of front brakes and struts in it ,but i still need to mount the new race seat and bleed everthing then i can almost drive it :D almost finished the inter cooler piping but i need to chop a pipe to get the last bend right
still waiting for the enzed guy to do my pipe he said he was coming around and i sadi the stuff was on the bench then i checked after work to see if he had done it ,but still hadent touched it ,then i rang him today and same story !
Posted on: 2011/1/13 14:43
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
