« 1 (2) 3 4 5 ... 9 »
Re: Silvia-Specr's Project Sleepy
From Vancouver, Wa
Been working on this project off and on, motor and trans all mounted up. still have to finish the trans tunnel. got the gas pedal done and the accelerator cable. water outlet has been modified so has the new radiator, alum pulleys, water lines modified, steering column is done, and the rack n pinion is almost done.
Posted on: 2011/1/19 5:17
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
From Vancouver, Wa
Finally got some new pics to upload
jpg  80'210 0011.JPG (94.33 KB)
11064_4d37ee797bcc6.jpg 656X492 px
jpg  80'210 0021.JPG (110.95 KB)
11064_4d37ef2c729a0.jpg 800X600 px
jpg  80'210 0041.JPG (127.07 KB)
11064_4d37efa321efb.jpg 800X600 px
jpg  80'210 0031.JPG (97.06 KB)
11064_4d37efb79640b.jpg 800X600 px
Posted on: 2011/1/20 8:18
From Snohomish, WA USA
Release the Beast! Sweet motor. I want to see more.
Posted on: 2011/1/21 4:23
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Vancouver, Wa
Thanx Ernie, just finished up the alternator
Posted on: 2011/1/22 3:57
Is that a B210 tunnel, or a 1200 automatic tunnel? How's it fit the SR20?
Posted on: 2011/1/23 1:05
From Vancouver, Wa
That is my 80 210 tunnel that is cut out, with the sr20 trans in it.
Posted on: 2011/1/23 8:12
From mandurah
nice work ,what rack are you using and what mods to get it in ??
keep the updates comin
Posted on: 2011/1/23 10:16
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Vancouver, Wa
Alternator all painted up and installed, thermostat housing too. Thanx Estyre, the rack is out of a 240sx, had removed the steering column and and modified the end to make it splined instead of having the rag joint, using two steering u-joints out of the 240sx and the slip shaft, at first i will run without power steering to see if it is needed. added the stock rack brackets onto the crossmember. bought some poly bushings for it, I will be running the 240sx front suspension.
jpg  80'210 0421.JPG (134.23 KB)
11064_4d3d1749462e5.jpg 800X600 px
jpg  80'210 0431.JPG (119.36 KB)
11064_4d3d175c86bb7.jpg 800X600 px
Posted on: 2011/1/24 6:08
Nice work!!
My motor is ready to go back in as well. I'm looking at redoing my SC plumbing.
Posted on: 2011/1/25 15:01
'73 2 Door Sedan
From Vancouver, Wa
Thanx Ernie, I should be getting back the radiator, water lines and my intake before the weekend, so hopefully will get to work on it some more. After that i should be able to finish up the steering rack.
Posted on: 2011/1/26 6:27
