« 1 (2) 3 4 5 6 »
Re: Track car project
Not too shy to talk
From new zealand
Got new valve springs today.(new on left standard on right)
I skimed some more off the flywheel. Its about 6.4kg now.
And A pic of my reground cam and my head.
jpg  P1040497.JPG (144.80 KB)
14796_4d3e9130d45ae.jpg 640X480 px
jpg  P1040503.JPG (146.15 KB)
14796_4d3e9141c597a.jpg 640X480 px
jpg  P1040499.JPG (148.61 KB)
14796_4d3e915a21cdf.jpg 640X480 px
jpg  P1040502.JPG (146.48 KB)
14796_4d3e9172caecf.jpg 640X480 px
Posted on: 2011/1/25 9:02
From Melbourne AUS
im loving this build.
i think a budget track car is one of the best ways (if not the best way) to enjoy a datsun
Posted on: 2011/1/25 13:55
1973 B110 A12
1973 B110 SR20VE
From sydney australia
All you need now is to find some side draught carbs & a manifold & it should be lots of fun. Can I be rude & suggest you leave those ports as they are, with the stock diff ratio & such. If you went too big you'd lose low down torque & make the engine peaky & a pain to drive. Nothing better than having an engine thats not 'gear sensitive', so when you put the foot down it goes, it doesn't have to wait til a certain point. I admit you might lose top end HP, but not that much. It's all about gas velocity & getting the air moving as soon as possible. The same amount of air travels faster in a small tunnel than in a big tunnel.
Posted on: 2011/1/25 14:14
From dominican republic
hey datmbl can you tell me the dimentions in milimeters of the doble valve spring?
thanks
Posted on: 2011/1/25 20:46
From Ballarat Victoria
Im loving your project too.. Keep posting the changes you make and the coresponding lap times each time you get back from the track.
Maybe post what your car setup is? Things like camber, caster, toe, spring rates, shocks etc. And any changes you might try at the track.
Enjoy!!
Posted on: 2011/1/25 20:56
1200 Coupe-
A12, E85, EFI + Turbo = FUN
260Z 2 seater-
L28, 50mm TB`s, 297HP = MORE FUN
Not too shy to talk
From new zealand
I have buffed the casting marks off in the ports on the head
probley just leave it at that. webers fairly costly now(sold a good set a few years back and kicking myself now)maybe look at bike carbs?
valve springs measure 29.5mm od 22mm id 50mm high (free length) for outer and 22mm od 16.8 id 44mm high for inner spring.
Posted on: 2011/1/26 2:17
If you could pick up a set of big bike carbies, then it's just a case of making the manifold. I agree much cheaper than webers.Aidan (Dat141) had such a set up originally on his sedan, & I'm sure he or any others would only be too glad to help. Anyway,you've got that DGV on it, so it's something that can be done when money becomes available. Get out there & have some fun with what you've got, rather than sitting around doing nothing while you wait for a win in Lotto.
Posted on: 2011/1/26 4:12
Not too shy to talk
From new zealand
Next sprints on 10 april. Motor half built. Does any one know where febuary went?
Posted on: 2011/3/15 7:55
From Wellington
Hey thats cool, how do you get on the track at manfield??
Posted on: 2011/3/15 8:38
Not too shy to talk
From new zealand
just get in touch with Julian at motorsport wanawatu.He runs the road and track series(hes got a 1200sss). the web site is www.motorsportmanawatu.org.nz. only need a helmet overalls and a fire extinguisher. cost a bout $65 and just keep going out as many times as you can.
Posted on: 2011/3/15 8:56
« 1 (2) 3 4 5 6 »
