B310 Diff Length
Hey.
Just Did A Quick Search But Cant Find It On here.
Looking To Find Out The Length Of A Datsun Sunny B310 Diff Housing
Cheers
Posted on: 2011/2/4 10:10
Re: B310 Diff Length
Width is unknown. None of the lazy blokes on here ever bothered to measure one!
The track is:
B310 tread: 1300 mm
B110 tread: 1245 mm
B310 wheels are 1/2 inch wider with same offset.
So the width drum-to-drum should be 68 mm wider (2-1/3" wider) than a 1200 housing.
Posted on: 2011/2/5 3:19
From gold coast QLD.
B310 Sunny(4link type)width is 1360mm drum to drum,maybee you can put the measurement in the wiki DD.
Cheers
Bert
Posted on: 2011/2/5 4:39
From Vancouver, Wa
sunny b310 rwd is 1360mm or 53.5"
Posted on: 2011/2/5 5:03
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Thanks guys. Added to Diff Widths
•Datsun B110: 51.36 in (1305 mm)
•Datsun B310: 53.5 in (1360 mm)
55 mm difference (2")
Posted on: 2011/2/5 5:59
From Christchurch NZ
I may as well chime in too and say that the C20 vannette diff is 105mm wider than a 1200. That should be around 1400mm.
Posted on: 2011/2/6 3:45
Forced Induction!
From Portland OR. USA
Anyone got a width measurement for the width of the B210 H150 axle?
Posted on: 2011/2/9 21:43
It is same as B110, or maybe a slightly different.
Posted on: 2011/2/10 3:45
That's what I thought, after thinking about it this afternoon. It's been too many years since we were measuring and scheming...
Posted on: 2011/2/10 4:56
