5 Stud
From Brisbane, QLD
Does anyone know what hubs fit a 200B strut, and how to go about changing it. Hoping to fit a 5 stud hub as more rim options are available.
Cheers, Nick
Posted on: 2011/2/4 12:22
Re: 5 Stud
From Brisbane, QLD
B U M P
Posted on: 2011/2/5 10:33
71 B110
Re: 5 Stud
From Goulburn NSW
Hi how are u? check out the maddat website they do brakes to fit just about all datsuns,they do brakes to match the 200b/stanza strut as they do alot to do with the conversions for example ca18det into 1200 ute which when doing that conversion u need to do brake/strute upgrade anyway check out the website and i hope u find what u need.They also do 5 stud by request
Posted on: 2011/2/6 6:27
Re: 5 Stud
From Geelong, Vic
pretty sure vn commodore hubs fit on, very similar wheel bearings i think the spacing of them might be just slightly different
and XF falcon front hubs also fit im pretty sure
otherwise z31 300zx hubs fit straight on
might be able to fit 240/260/280c hubs on
and no doubt older toyota 5 stud hubs would also fit as their 4 stud ones do
Posted on: 2011/2/6 8:14
Re: 5 Stud
From Brisbane, QLD
thanks for all of these replies, big relief that you can change hubs as i was stumped for rims.
Cheers, Nick
Posted on: 2011/2/6 9:21
71 B110
Re: 5 Stud
From Coondle, WA Australia
dont forget thatif you are buying new rims, you can get them drilled to suit any stud pattern.
Most rim manufactueres allow you to buy "blanks".
You just have to ask about it.
Posted on: 2011/2/6 9:24
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: 5 Stud
From Brisbane, QLD
thanks everybody for your replies. i will try and work with everyone of the ideas. reuby_tuesday, i honestly didnt know you could order blanks, thats a big help.
Cheers, Nick
Posted on: 2011/2/7 0:31
71 B110
Re: 5 Stud
From Goulburn NSW
did u check out the maddat website there is #OOPS# loads of stuff on there
Posted on: 2011/2/8 7:05
