Re: Master Pump Problem
If you put oil in it, that is a problem. Only Brake Fluid should be used.
Yes chris, that's correct. Push in the piston, then fit the screw to limit the front piston travel. This is for a double-outlet Master Cylinder.
And yes, the Master Cylinder must be bled by cracking the lines at the cylinder, before proceeding the bleed the wheel cylinders. All air must be removed.
Posted on: 2011/2/18 6:49
Subject Poster Date
     Master Pump Problem Sumith 2011/2/16 16:05
       Re: Master Pump Problem ddgonzal 2011/2/17 4:17
         Re: Master Pump Problem Sumith 2011/2/18 6:07
           Re: Master Pump Problem ddgonzal 2011/2/18 6:22
             Re: Master Pump Problem Sumith 2011/2/18 6:37
               Re: Master Pump Problem clyons8 2011/2/18 6:45
                 Re: Master Pump Problem ddgonzal 2011/2/18 6:49
                   Re: Master Pump Problem Sumith 2011/2/18 7:04
                     Re: Master Pump Problem ddgonzal 2011/2/18 7:11
       Re: Master Pump Problem Anonymous 2011/2/17 8:44
       Re: Master Pump Problem dattoman_1000 2011/2/18 10:59
         Re: Master Pump Problem Sumith 2011/2/18 11:08
         Re: Master Pump Problem dattoman_1000 2011/2/20 3:40
