(1) 2 3 »
Extra-large Brakes for Datsun 1200s - Bolt On
258 mm disc brakes -- no fabrication, no welding
* Lightweight disk rotors
* keep your lightweight 1200 disk struts
* fits under 13" aluminum wheels & 14" steel wheels
* No modifications needed to master cylinder
Edit: will fit under 16 & 17" wheels too
The calipers are from:
* Nissan B11/B12 (Sentra/Sunny)
* Nissan Pulsar N12/N13
wrecker are full of these, but re-manufactured are only $21 each
The rotors are from:
* 1982-1983 S130 (280ZX)
* 1982-1988 S110/S12 (200SX)
* 1982-1984 910 six (Maxima)
Posted on: 2011/3/1 4:49
Edited by ddgonzal on 2011/3/1 5:05:05
Edited by ddgonzal on 2011/3/2 5:05:51
Edited by ddgonzal on 2011/3/2 5:13:11
Re: Extra-large Brakes for Datsun 1200s - Bolt On
Rotors are only $20 each new
Remove the 1200 disks from the hub, then put the hub back on
Slip the new disks over the hub
you will need slightly longer wheels studs, from a wreckers or buy them new
Posted on: 2011/3/1 4:59
From Las Vegas USA
OK what are those calipers off of?
Tom
Posted on: 2011/3/1 5:03
From Nyngan, nsw Australia
dav when you say 258mm what model you talking about also what caliper, also will nissan stanza standard from disc bolt straight on ??
Posted on: 2011/3/1 5:05
living is good,.....
The rotors are 280ZX rear disks.
These have nothing to do with Nissan Stanza
Posted on: 2011/3/1 5:07
Doug Morrisun from Oregon came up with this idea: the lightest, largest brakes that would fit on the stock struts.
To keep weight down, his idea was to use a solid rotor. Non-vented. He says that for a light 1200 street vehicle there is no fading.
Posted on: 2011/3/1 5:09
Posted on: 2011/3/1 5:13
Oh, here's the trick. Need a caliper spacer/adapter
mklotz of Datsun NL320 disk retrofit fame is making some sets of the adapters. In fancy colors.
Posted on: 2011/3/1 5:18
Quite a regular
From Olympia, WA, USA
I Like
Posted on: 2011/3/1 5:57
"Horsepower... May you always have enough"
From Vancouver, Wa
Me Me Me Me, I want some!!!!!!
Posted on: 2011/3/1 8:30
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
(1) 2 3 »
