« 1 2 (3) 4 5 »
Re: My L18 coupe
From Armidale N.S.W
Wow missed this build Sweet as mate awesome work. Wondered where pigs old donk went to was so tempted by it and im thinking of going back down the L series path again with me coupe or wagon. There an awesome motor would be even sweeter with a turbo setup.
Posted on: 2011/2/28 22:34
73 1200 wagon SOLD
Re: My L18 coupe
couple more pics, tried the matte black bonnet and didn't like it
jpg  IMG_0141.jpg (118.43 KB)
12844_4d6f7bcc1bb15.jpg 640X478 px
jpg  IMG_0166.jpg (106.34 KB)
12844_4d6f7bddc00ad.jpg 640X478 px
jpg  IMG_0182.jpg (138.71 KB)
12844_4d6f7c013a9d6.jpg 640X478 px
jpg  IMG_0183.jpg (118.18 KB)
12844_4d6f7c1521244.jpg 640X478 px
Posted on: 2011/3/3 11:33
Re: My L18 coupe
From mandurah
looks awsome with those wheels and flares !!!
what specs are the wheels ? width and offset ?
nice work !!
Posted on: 2011/3/3 13:48
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: My L18 coupe
gotta love this coupe. not cause its a coupe, color.stance. engine- its a combination.
not sure bout the rear cannon, might be mighty loud with that l18 up front.
Posted on: 2011/3/3 19:24
Re: My L18 coupe
Yeah the cannon is definitely going, it's getting a new exhaust system from the extractors back, will just have a tucked up high blacked out dump pipe at the back, I'll run a muffler before the diff and maybe a hot dog before that
Posted on: 2011/3/7 5:48
Re: My L18 coupe
mmm black bonnet might look better if you do black boot too. im doing that and black fuel flap. might as well make it look like a bumble bee.
Posted on: 2011/3/7 10:01
Re: My L18 coupe
I had that setup already orange with black bonnet and boot and fuel flap but it holds a heap of heat in the car
Posted on: 2011/3/7 10:12
Car free
Re: My L18 coupe
From Melbourne, Australia
if the paint is gloss, black bits have to be gloss. if paint is matt black has to be matt. it looks so bad because the paint finish is so different between the two
i want to recommend a couple of things but then i'd just be telling you to do it same as mine... so that makes me think im just biased lol
better to be different, and it does look awesome as is
Posted on: 2011/3/7 10:20
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: My L18 coupe
From Geelong, Vic
so you got it running yet?
i was actually running a 2 inch ish spacer on that tailshaft when it was behind the CA, so most definately can be done. dont remember any bad vibrations or anything like that up to about 200kph...so its probably pretty right
other think you could do is get the diff flange from a H165 as they are longer than the h190 and should still go onto the pinion so that will take up about an inch atleast so then you wont need as much of a spacer. then the other flange i gave you with the tailshaft should go straight up
i was running 2.5 inch exhaust with a single offset straight through muffler....sounded pretty tough. was also pretty loud but you get that when you have exhaust and carbies making noise at the same time
Posted on: 2011/3/8 1:16
Re: My L18 coupe
The coupe drove under it's own steam today, not by me though but by a mechanic mate
He said it goes pretty good, not sure how to interpret that but he did used to own a 10 second Ca 1200 wagon so not sure what to expect. Hopefully have it home soon
jpg  IMG_0327.jpg (62.29 KB)
12844_4e15a52265ca9.jpg 640X478 px
jpg  IMG_0354.jpg (76.69 KB)
12844_4e15a52fb246c.jpg 640X478 px
Posted on: 2011/7/7 13:28
« 1 2 (3) 4 5 »
