(1) 2 3 4 »
time for new brake pads... what do you guys suggest? (road/race)
From Melbourne AUS
will an intermediate type pad (street/race) offer any better braking performance?
or will they just withstand higher temperatures?
currently im running standard bendix road pads in my ute with 250mm s13 discs/calipers
ive done 4 track days and a couple of hillclimbs plus about 15,000 road klms on them
they have about 1/4 left on them but im thinking ill change them now before hitting wakefield at the nats next month.
i cant fault the setup currently so im wondering should i stick with
what i know works or is it worthwile going to a semi race pad while im replacing them?
if so i'd like to know what type/brand of pads you think i should go with?
cheers!
andrew
Posted on: 2011/3/9 10:34
1973 B110 A12
Re: time for new brake pads... what do you guys suggest? (road/race)
From Perth
So your using the smaller CA style caliper
So your pad shape should be the same as N13 Pulsar ... DB1117
Personally I would maybe try some Lucas or Remsa pads
Not too cheap... but not too fancy either
Posted on: 2011/3/9 11:43
From Sydney NSW
Bendix ultimates are cheap and will not fade if your car isn't too heavy. They are a pretty sweet pad and don't cost a million bucks, I would recommend them. I have gotten them pretty hot in a 1300kg car and they still hold up. Make sure you bed them in properly though that's the most important part. Not sure about how good they are over a long period of time however.
Posted on: 2011/3/9 15:38
From Canberra
Andrew,
Unless you want to go for a track day pad and pay the $$$ otherwise I would recommend Lucas TRW pads.
These are cheap and seem to work pretty well.
Bryan
Posted on: 2011/3/10 4:48
From Melbourne AUS
well the bendix im using currently are cheap and work really well too
im just wondering if theres anything to gain from going to a semi race pad?
anyone had any experience with any particular brands?
Posted on: 2011/3/10 10:40
1973 B110 A12
From brisbane
Hey Ange
I have had a good run out of Intima pads. I use the SR version which is the intermediate one.
They are about $120 on Ebay.
Cheap and they work.
Posted on: 2011/3/10 12:18
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Melbourne Vic
For a proper race pad that is cheap i run QFM brand A1RM compund. same as race brakes pads but cheaper. great on the street work well from cold have a great high temp rating and work great on the track twice as good as bendix ultimate and they are cheaper!
Posted on: 2011/3/10 12:22
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From brisbane
Lags - I have just fitted a set of A1RM pads for a track day tomorrow. I will advise how they go after the weekend.
I have heard plenty of good things about them so I thought I might give them a crack.
Posted on: 2011/3/11 0:50
From Sydney
I have had excellent results using Ferodo DS-2500's. Oz distributor can be found here: Comp Friction
Posted on: 2011/3/11 1:55
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney,NSW
I ran Bendix Ultimates all last year... Thought they were great...
Then tried SBC Carbon ceramic pads, Race brakes cut them to suit your calipers and they are AWESOME, Pedal feels SO much better and im braking a whole heap later with confidence!
Race brakes cut them to suit (GTR calipers, same as wrx,evo pads), the pads are $250 and cutting is 100, so not the cheapest but im really impressed.
The other downside is the carbon ceramic puts a coating on your discs, so they need a light machine if you go back to normal pads.
I actually have a set of the QFM's Lags was talking about, forgot i had them and went straight to these.. heard they were worth a try.
Posted on: 2011/3/11 2:21
(1) 2 3 4 »
