Browsing this Thread:
1 Anonymous Users
Re: White / Carbon Fiber face gauges, anyone? |
From Perth WA AUS
Blue looks cool, I might change my LED's to blue soon. Carbon look is awesome!
Posted on: 2011/3/30 13:26
Datsun 1200 2Dr sedan.
From mandurah
yea carbon looks sick !
so if i change the plete in my ute cluster from a mph to a kms plate ,will it work and tell the right speed ?
i was going to messure the 2 and check that 160on a kms dash is in the same spot as the 100mph on a mph dash
does anyone know aht i mean ,its the plate with about 6 tabs on it to mount to the cluster ,and it has the speed writen on it so the incriment plate ,ae they changable and still be accurate ?
Posted on: 2011/3/30 13:32
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From Mandurah, Western Australia
Should be jesse, Ive got one of the original retro fitted stickers that read mph and kph.
Top idea with the stickers, better that the ones I done years ago.
Posted on: 2011/3/30 14:15
From Northeast USA
Thanks for the input everyone and for helping me point out the mistakes. I will sort this issue out . Don't want to sell something is not good. As of now I only have the US/ MPH version. The km/m I will work on .
On the Superbrightled.com website, look for the 12 volt miniature wedge bulbs type 194 /168. There are 4 options here. The more led's on the bulb the pricier they are. I went with the WLED x1 which is the cheapest out of all. For extra brightness , you should go with WLEDx6, but then again, it's all about how much you want to spend. These are high quality. On the Carbon Fiber overlay, any color will look good,but no brightness will show thru, only around the faces. Guys sorry for the mixup. I will correct the gauge issue and will let you know.
Gerry
Posted on: 2011/3/30 18:11
- Gerry -
From Northeast USA
Guys, Im gonna need either a scan, or a picture just like this one, the same angle  . Ive tried with the picture I've collected but they don't work
Posted on: 2011/3/31 1:49
- Gerry -
From Albany, Perth Australia
sent you a few more pics of the speedo that should help you make copies
Posted on: 2011/3/31 14:13
1200 Smerf Mobile
I'll send extra payment for tachometer as well, so once you have sorted the kmh problem out I'll speak to you then thanks nick
Posted on: 2011/4/1 2:44
Car free
From Northeast USA
Well Thanks to datski620 I got the correct pic. I have already designed the km/h face in the correct format and once I put it all together I will post a pic!
gerry
Posted on: 2011/4/1 3:05
- Gerry -
Top work gerry...can't wait to see picks and will have to order a set for sure
Posted on: 2011/4/1 3:09
1200 Smerf Mobile
Registered Users Contentmaster Usermaster
This is from a scanner:  I took a speedo apart to fit that into the flatbed scanner. So the DPI should be spot-on.
Posted on: 2011/4/1 23:35
