battery setback
farther back than normal. These are a good size battery for an A-series engine (a bit larger than the JDM battery). Guess you could fit one just about anywhere.
Posted on: 2011/4/2 7:58
Re: battery setback
From ACT Aus
mines is about half a foot in front of my rear left wheel, pain in the arse to get to
Posted on: 2011/4/2 11:11
unfamilia wrote:
You have bump stops? Your soft
Re: battery setback
Quite a regular
From Olympia, WA, USA
I was thinking of putting one close to the firewall. As my car is LHD and has a front distributor there's a little extra room there. Allowing for a little 'mass centralization'. What size battery is this?
Posted on: 2011/4/2 17:01
"Horsepower... May you always have enough"
Re: battery setback
I dunno the size. I went to sears and bought their smallest automotive battery which is group 26.
Next time I will go to Walmart and buy a lawn tractor battery. Some guys run those in their 1200s with no problem.
Posted on: 2011/4/2 20:09
Re: battery setback
From Coondle, WA Australia
For a stocker A12 a 350CCA lead acid battey should be more than enough, and they are about the same size as in the pic.
Im sure you could run with a 280cca or less, but you would want to make sure it starts easy all the time. One carby flood and 30 seconds on the starter would drain a small battery pretty quick.
The Calcium-calcumim hybrid batterys seem to about the best ive found for compact power, but they are alittle pricy. I got a 3 year warrenty with all the ones ive bought, (350cca and 800cca units), so i reckon they are good value.
Posted on: 2011/4/3 3:21
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: battery setback
From Manila Philippines
got any pictures? :)
Posted on: 2011/4/3 17:28
Re: battery setback
JDM battery as fitted to many new cars:
Height: 20.4 mm (7-7/8 inch)
Width: 18.8 mm (7-3/8 inch)
Depth: 12.8 mm (4-7/8 inch)
Weight with acid: 9.7 kg (21.4 pounds)
CCA: 274
Capacity @ 20 Ah: 33-35
Reserve Capacity Minutes: 52
Battery
Group 26 battery is a lot lighter (only 31 pounds) and more powerful than the original specification.
Posted on: 2011/4/3 17:53
Re: battery setback
From Portland OR. USA
I've been running the Odyssey PC680MJT batteries in both 1200's. One has been in use for a year, the other has been in 2 years. 220 CCA, very small, and 15#.
http://www.summitracing.com/parts/ODY-PC680MJT/
Posted on: 2011/4/3 18:19
