« 1 ... 1701 1702 1703 (1704) 1705 1706 1707 ... 1777 »
Re: PERTH BOYS.. GO THE DATTO
From Coondle, WA Australia
Its interesting to note, that despite all the post whoring going on here, this thread was started by young Joel, asking how he could lower the engine to fit the frypan under the bonnet.
Somehow, this thread has managed to get back on topic eventually after many pages of ,lets be honest, crap.
Joel.
List what needs to be done.
Next to each item, list the steps that you have already taken to try and resolve the problem, so that folks can prepare reasonable answers, advice, and be prepared if you con them to come around.
Eg
Issue/Symptoms : brake pedal feels spongy when first applied, but gets harder the more I pump it.
Steps taken:
I have checked the fluid resiviour and its full.
I have checked each wheel cyclinder and there appears to be no leaks. I checked this by removing the wheel, and drum to inspect inside as well as inspecting the outside of the backing plate.
Other : The wheel cyclinders look to be the original units.
With this detail and level of information, you will find people will be able to point you in the right directin, and give you some more help. You go away, do the suggestions and come back with the resoultion. It worked! or nah that didnt work, and update the problem list with what has changed if anything.
Tackle one issue at a time and make it easy on yourself. Once you have worked out all the easy stuff, and all that is left is co-dependant issues left, then the gurus might decide to rock up and help out.
Posted on: 2011/4/2 0:17
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From mandurah
Well said ! ,try some simple stuff to start Joel then if you still get stuck ,we can help
Posted on: 2011/4/2 6:44
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
can we then get back to whoring?
Posted on: 2011/4/2 8:10
From Perth WA AUS
Are we back on topic?!?!
Damn :)
Posted on: 2011/4/2 8:45
Datsun 1200 2Dr sedan.
From mandurah
Haha no nigel this thread is in offtopic ,so yes keep whoring :D
Posted on: 2011/4/2 9:02
I spose it was somewhat vain to try and bring this thread back on topic. What chance did i have anyways? (i suspect nil and bugger all)Bescides I dont want to take that away from you guys else i risk an invasion back to my build thread... that I havent started. Hmm on the to-do list.
I havent heard back from Joel yet, so I hope that means he has gotten some motovation and is busy under the coupe.
So back on topic, as in post whoreing.....
Posted on: 2011/4/2 23:25
Is this you unfamila at the supermarket buying your "supplies"
pimpin!
Last time I checked Levey, going to work in a superman outfit doesent make you any better at what you do. (sorry its early and im not much good at this!)super-cape
cant get stupid pics to display.....
Posted on: 2011/4/2 23:50
Edited by reuby_tuesday on 2011/4/3 3:16:00
From Perth WA AUS
Hahahaha, Walmart seems like a classy place!
Posted on: 2011/4/2 23:56
From perth western australia
hey sorry guys im not always online atm as yes i havebeen busy working at ugl and working on the car. things that need to e fixed are just a tune holes in the floor welded up and the gearbox needs to be fixed... im pretty sure it it the thust bearing that is forked. the gearbox makes a grinding noise when the clutch is all the way out and wen i put the clutch in it goes away.. as i have very very limited tools i cant do much mechanical work to the beast i am able to buy beers and lunch/dinner or what ever anyone is wanting as payment i have the motivtion to finish her as she is my baby i dont have a stupid friggin mrs who whinges about me touching my car. it is just me now. lots of money has been spent which im not worried too much as everything does cost money. and yes i have had a shiet load of help from yous fellas which is much appreciated.
Posted on: 2011/4/3 7:45
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
ruby you got nige on a good day there. he was wearing more than just his undies on the out side
as for me, im more like this
Posted on: 2011/4/3 9:42
