A12 more power with su's or ware of time?
From West syd
Hey ppl I'm thinking I ither do su's or a dodgy turbo set up on my a12 I need more power it's bog stock right now. Im not chasing 12sec pass just e nuff balls to play with v6 commodores not beat them just enuff to stay with them
Posted on: 2011/4/3 22:56
Re: A12 more power with su's or ware of time?
adding SUs won't give you much more power. A simple turbo setup at 5 psi and no intercooler will provide more power.
To get the advantage of the twin Hitachi carburetors, you need to change the head, camshaft, pistons and exhaust. And then keep the engine revved up to around 6000 rpm.
Or just fit a stocker A14 to get around the same performance.
Posted on: 2011/4/3 23:07
From Coondle, WA Australia
A stock A14 should give you some extra go.
An ag turbo setup. ie j-pipe setup. no intercooler. If you are handy with a welder, i reckon you could hack something up in an day. Half a dozen hose clamps, a few silicone elbows.
just remember. Cheap, realible, powerful. You can only pick two...
I just chucked j-pipe into the fast search bar and got this.
1200RC setup
Posted on: 2011/4/3 23:16
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From perth airport
thats a very good way of putting it
or u can pick 3 just add lots of coin :(
Posted on: 2011/4/4 0:37
perth airport parking
Datsun 1200 ute A14
As Sean (whitesedan) put it:
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
A14 is your best trouble free, low cost power improvement. Turbo will bring jetting drama's and need a fair bit of work. Find an A14/15 to drop in and work on the turbo A12 when it is out and about.
Posted on: 2011/4/4 1:27
I would say stick with the a12 turbo and change your diff ratio down to 3.9.
That way you wont need a 5 speed. An a14 has longer stroke and gets noisier
at 100kmh than an a12.
Posted on: 2011/4/4 1:41
From West syd
I'm thinking I'll turbo it. The so called j pipe I got a rb20 turbo laying around mite use that unless someone on here is selling a setup even half done would help
Posted on: 2011/4/4 3:24
I do infact have a good turbo setup that came from a 1200 for sale, although i suspect it may be a little out of your price range, judging from you initial intent.
Includes
Rebuilt CA18 turbo
External wastegate (Streetsmart 38)
exhaust manifold to suit both.
intake manifold with injector bosses and injectors (ca18 reconditioned)
ca18 throttle body.
PM me if you are keen and we can talk.
Posted on: 2011/4/4 4:39
