« 1 ... 9 10 11 (12) 13 »
Re: A14/15 turbo~280hp, bore question
Cool.
That is basically what I had, very similar actually (2d format rather than the format with cap-struts and raised rails like some newer engines have). My clearance issues were with the sump though and I think the weights fouled as well, I need to dig all the parts up again and fit them together, but I remember it being something simple (with the counterweights) like incorrectly drilled holes or something along those lines. I'll look for the one I made and get some pics up.
EDIT: Thanks for the clarification by the way, I sorta winged it and it was okay but needed another version or two before being usable.
Posted on: 2010/11/8 12:12
From Brisbane
D - I think my 82mm is about the limit, but who knows, will let you know when I get mine done.
I've got it all worked out how to do the sleeving in my head, just need to put the time into the machining.
I haven't been paying to much attention to the wet sleeve job at the moment, been working on another big capacity project, just waiting for the pistons to turn up.
Just a tease - it's over 1700cc. All things going well should have it running by Christmas.
Posted on: 2010/11/8 12:21
Gary, just over 1700cc must be a 4age, g16b, cg13de, ga16de, e16 or motorbike engine!!! :)))
Jmac, that holden has a fully counterweighed crank! cant remember ever seeing one
on any holden except the maybe the last of the cast iron holden v8.
edit; Jmac confirmed its a blue or black crank which ap had them
A series even had alloy heads which holden 6s never did from factory.
Posted on: 2010/11/9 5:47
Edited by D on 2010/11/15 1:50:22
It's probably lucky holden didn't do an official alloy head for those motors - if you knew how much core shift there typically is in the later 12 port blue/black heads (and even porousity issues) - it would've been even worse!
Posted on: 2010/11/15 10:27
John McKenzie
From Forsby Finland
The spring is approaching fast here in Finland and I finally got my parts back from machining last week, here are some pics of the 79mm bore A15 block and the modified conrods. I have also installed a Megasquirt managment system in the car. I will keep you guys updated!!
Marcus
Posted on: 2011/4/5 19:43
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
If I was on the net when I was 15 yrs old id say "SICK MATE"
but since kiwi mates have diseased me with Its Terminal cuz :)
I guess for Datsun freaks it is a permanent affliction.
Posted on: 2011/4/6 0:31
From Forsby Finland
Wait and see, 280hp and 690kg will be sick enough for me :)
....But in Sweden anything under 1000hp is childish?
Posted on: 2011/4/6 18:46
Considering the video you posted of your dyno run had twin webers and worked as smooth as silk, theres no reason you wont reach 300+hp if the turbo is up for it.
In sweden they must the same kind of water you guys drink :)
Posted on: 2011/4/7 0:55
From Perth
Whats the origin of the rods... besides the fact they came in an Eagle box ?
Posted on: 2011/4/7 1:14
From Forsby Finland
I haven´t decided what turbo I will use yet but I have three different turbos on my workbench, I will choose between the GT25 and GT28.... maybe I will try them both! I would like to have a broad powerband instead of high peak power!?
Yeah, the Swedes sure drink the same water as we do, but there is still one big difference.... they have got plenty of $$$
Posted on: 2011/4/7 5:54
