« 1 (2) 3 4 5 »
Re: approximate power at the rear wheels?
That's still a fair bit or power for a, what? 1.48 litre, pushrod non-cross-flow.
But even what I wrote is a little optimistic. It depends on the cam specifications as well and the head flow specs. What valve sizes are they?
The big 45's should help with the high RPMs if they aren't choked down too much.
Looking forward to hearing how it goes dude, good work!
Posted on: 2011/4/13 14:02
From Sydney
cheers mate with the bore it will be roughly a 1.586l or something he hasnt worked that out yet... well i havent gone to see him to ask anyway.. and yea ill post up a video or pics of it on the dyno once its all done and running..
Posted on: 2011/4/13 14:05
From Rosewood, QLD
id be happy with 110hp at the wheels for an A series daily
Posted on: 2011/4/13 14:06
1971 B110 sedan project.
2012 Nissan Micra daily.
From Sydney
yeahh but the more the better :P
Posted on: 2011/4/13 14:07
From sydney.nsw
1586cc, that makes the bore 81mm with a a14 stroke(77mm). is it a a14 or a15 stroke.
Posted on: 2011/4/13 15:00
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From south coast nsw
if u get around same as what u had originally i would be happy.then get 13s and a light diff and remove excess stereo devices, and it would be like adding 50hp.
Posted on: 2011/4/13 15:41
From mandurah
wouldnt flat tops and a 60thou shaved head give it abit more that 10-1 CR ?
what pistons are you going to run ,what model mazda ??
cheers
Posted on: 2011/4/13 15:49
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Tracy ,Ca
ok hear are my engine specs 1400cc gx head ported custom valves 40mm and 33mm with 7mm stems custom bumpstick ground to match head flow figures around 300 duration wiesco custom pistons with dome 14.2-1 ratio knife edge crank comp oil pump twin mikunis crankfire ignition running through custom trans with webster gears and dog rings h145a with 463 limited slip on 114 race gas what do you think crank and rear wheel figures. kept destorying 56a middle close trans
Posted on: 2011/4/13 18:13
Bob, what are your specs? How much HP?
Posted on: 2011/4/14 1:21
From Las Vegas USA
Bob if I had to guess I would say 120 WHP (based on GT-4/5 knowledge) and perhaps 160ish at the flywheel.
As for a street 1200 , 86 HP at the rear wheels is pretty good. Keep in mind a full race A12 is at 100WHP, I can only speak for my car but with the 73WHP I've started into the beyond of what's streetable: the motor will plod around no problem but it really wants to be kept above 4000 RPM's and the gas milage is not that great (14 mpg on track).
Having had 2 stroke hot rod street bikes there is a definite threshold that starts to suck the fun out of a car or bike...........now if we could figure a way to take an A series out to like 1750cc or what ever that would be the way to go for the street, lower revs same power, nice flat torque curve etc.
Tom
Posted on: 2011/4/14 3:09
« 1 (2) 3 4 5 »
