(1) 2 3 4 »
aluminium rocker cover?
was wondering if anyone has made a aluminium rocker cover thinking of making one for my a12
Posted on: 2011/4/16 9:09
Re: aluminium rocker cover?
From Ringwood, Melbourne, AUS
I reckon this should be Chris's next job..
Get alloy rocker cover flanges cut, you could even cut the top out of the center of the flange, then just bend up some sheet for the sides and weld it up!
Posted on: 2011/4/16 9:12
Deano
i am willing to help out just wanted to see if anyone else has ideas i work at a engineering company and have already made some screw cut bits of aluminium to fit those pretty oil caps you buy from repco and am thinking of laser cutting aluminium copys of a gasket just need to do a program
Posted on: 2011/4/16 9:31
datsun a15 ute
Got full 3d drawings of various designs.
First CNC 5_axis cut is expensive, following cast items are quite cheap if numbers are good.
Have a whole host of different labels/titles to put across the top of the rocker assembly.
What is your engineering company? And what is your name?
Chris
Posted on: 2011/4/16 9:36
Oh wait are you selling these?
Do you have an image of the design?
Posted on: 2011/4/16 9:38
im not selling these mate just geting a few ideas together and a few parts together need to do a few drawings to see what i come up with (best appearance wise and simplicity) i am looking for my name is aaron and i work in narellan.
Posted on: 2011/4/16 9:55
datsun a15 ute
maybe we could manafacture some what is your capabilities chris sounds like your into machining?
Posted on: 2011/4/16 9:57
datsun a15 ute
Sounds good Aaron, my capabilities are near enough non-existent
But I can measure and I can 3d just about anything. Also pretty good with a spanner and I know the A-series fairly well.
I had some quotes in from various companies, do you have a CNC machine (what sorts)? I had planned to have these made through a friend of a friend in QLD but I haven't got round to doing a 3d print to test fit.
Chris
Posted on: 2011/4/16 10:13
I actually thought about using a blank head to slice the top section off
for a flange and then weld up the walls using durafix welding rods.
Finally a flip top lid made from chopping up a nissan L rocker cover.
Posted on: 2011/4/16 10:25
From Coondle, WA Australia
I reckon you could just make a trace of the gasket for the base, and do a square one to give it the "race" look.
Considering some of the racing rocker covers ive seen in photos, making up something like them should be achievable.
maybe I can justify the TIG welder i want with these...
Posted on: 2011/4/16 10:34
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
(1) 2 3 4 »
