how 2 remove a 120y sway bar
From Innisfail nth queensland
i have un bolted everything ho do i get it through the holes in th body without dameging it?
Posted on: 2011/5/2 9:22
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: how 2 remove a 120y sway bar
From port elliot , SA
the holes in the body i asume you mean the where the D rubber are on the body the 2 at the front ? they should un bolt too. as well as the bolts on the LCAs and it all drops down
Posted on: 2011/5/2 9:58
From Kyoto Japan
stone tray removed?
Posted on: 2011/5/2 10:04
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT!
Hayashi Racing
Secret Factory Japan
If you have a side of the car on the jack let it back down. When both sides are level you can unbolt it.
Posted on: 2011/5/2 10:19
From penrith,sydney,aus
i know what you mean mate there is 2 holes on the body which it goes through you cant unbolt it
i done the dodgy and cut 2 slots in mine so i could remove it and fit a larger one
Posted on: 2011/5/6 9:17
2 door 1200 sedan project l20b stroker
From Wardell. NSW.
Do you mean the two brackets the castor arms bolt to? I think they're called castor boxes. If so you can cut two slots on it and drop the cross member out. When i took mine out i was taking everything out so I unbolted the two brackets/boxes, unbolted the castor arms from the control arm, dropped the boxes off and slid the sway bar out that way. I thought it could be maneuvered out but maybe not.
Posted on: 2011/5/6 9:25
From RAdelaide
Easier way is to undo sway bar completely undo one lower control arm off the ball joint. Then maneuver out. Higher the car up the easier it is
Posted on: 2011/5/7 12:23
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
