Titanium Valves
From St. Louis, MO USA
Set of (4) used, in good condition titanium intake valves. 38mm face diameter, 7mm diameter stem. Length is 104mm. $100 usd set of 4.
Matching set of (4) exhausts, same as above with 33mm face diameter. $100 usd set/4.
Shipping $20 usd.
Peter
PeterZekert (at) Juno (dot) com
Posted on: 2011/5/4 18:49
Re: Titanium Valves
From mandurah
Hhmm might be keen, how much work is needed to put them in a h89 ?
Posted on: 2011/5/5 0:30
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: Titanium Valves
From Perth
Some 7mm guides would be the first thing
Call a headshop and ask how much to supply and fit guides
Posted on: 2011/5/5 0:32
Re: Titanium Valves
7mm stems are thinner than the stock 8mm so don't block the airflow as much.
I think the stock valve seats can be bored out to 38mm.
Posted on: 2011/5/5 3:29
Re: Titanium Valves
Great prices!!! Titanium valves would save 30-40% weight?.
I wonder if someone out there in Finland is hiding a
roller cammed, roller rockered, titanium valved, titanium retainered,
hollow billet camshaft A series that spins faster than going down a
steep and heavily lubricated naked booby / booty slide?
Posted on: 2011/5/5 4:56
