« 1 2 (3)
Re: fast indicators on 93 rodeo
From Coondle, WA Australia
DD. ill check for a second flasher relay and check that. it cant hurt.
Posted on: 2011/5/9 14:14
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Mandurah, Western Australia
Has it got a towbar. If so check for corrosion in the socket. The problems of flash rate is usually something wrong with the total load of all the globes in the circuit.
Corrosion in the trailer plug will cause a change in impedance or even a wrongly wired socket.
Posted on: 2011/5/9 15:57
Yeah its got a towbar. Didnt think of that. I would have thought that corrosion, and therefore a bad earth would make the indicators go slower. Still ill check that bit out.
Looked for a second indicator relay/can. Its only got one, so thats not it.
Posted on: 2011/5/10 2:55
From mandurah
Larger globes (wattage) or aload resistor rueby ,i fixed a patrol yesterday with the same problem
Trailer plug will only come into play if there is a short or if it is plugged in and is faulty
Posted on: 2011/5/10 7:26
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
« 1 2 (3)
