E O I - A series underdrive crank pulleys, Aust.
Quite a regular
I am having a 3 1/2 inch Diam lightweight single groove underdrive pulley machined up from billet steel for A series motors. Standard pulley is aprox 5 1/2 inches diameter, the 3 1/2 inch diam will spin the water pump and alternator at lower rpm than std pulley meaning power gain and less cavitation in the water pump at high engine rpm.
The 3 inch diam is approx same size as original Datsun works pulleys.
To keep costs down I have had these costed based on a run of 10 units, If anyone is interested in having one of these pulleys the cost is $225.00 plus postage.
8 units are up for grabs.
Reply if interested.
Posted on: 2011/5/10 8:11
Edited by beaufort on 2011/10/6 3:17:25
Re: E O I - A series underdrive crank pulleys, Aust.
From Rosewood, QLD
wouldnt water cavitation be worse with one of these cause they will be spinning even faster?
please forgive my ignorance and educate me.
Posted on: 2011/5/10 8:15
1971 B110 sedan project.
2012 Nissan Micra daily.
The smaller the drive pulley the lesser the rotation of the subsequent pulleys.
If the pulley were over-sized you would speed things up.
Posted on: 2011/5/10 8:32
From Sydney
with an underdrive crank pulley, the alternator and water pump will spin at a lower RPM in relation to the engine rpm. Worth noting that the alternator will start producing charge at a higher engine RPM as a result. e.g std charge starts at ~ 1500 engine rpm, when being driven via a undersize crank pulley, the charging will occur around the 2000 rpm there abouts. Ideally underdrive pulleys are suited to high RPM engines when you want your alternator and water pump to operate at more realistic speeds.
Posted on: 2011/5/10 8:34
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Rosewood, QLD
ahh cheers Chris and Benny i had it all backwards, long day at work.
Posted on: 2011/5/10 8:38
From Brisbane
Deleted my stuff so as not to be confused with what beaufort is offering - sorry mate.
Posted on: 2011/5/10 8:39
Edited by Lemonhead on 2011/5/10 10:41:18
Edited by Lemonhead on 2011/5/10 10:41:46
From Rosewood, QLD
does look sexy
Posted on: 2011/5/10 9:16
From Ringwood, Melbourne, AUS
I am interested..
What about machining a common tooth pattern into it for firing a crank sensor? I.e. something like the 36-1 that is needed for running a MegaJolt ignition controller?
If not needed it is simply not used but otherwise makes the pulley a hell of a lot more useful!
Just a thought..
Posted on: 2011/5/10 9:35
Deano
Quite a regular
Underdrive
Think of it this way, underdrive means to slow down. Underdrive crank pulleys are designed to slow down engine accessories and reduce parasitic loss.
Crank pulleys, attached to the outside of the crankshaft, are the source of power for a car's accessories. The alternator and water pump are belt driven units, attached to the crank pulley, that use horsepower from an engine to provide their own services. This draw of power by these accessories is called parasitic loss. Underdrive crank pulleys increase an engine's throttle response and horsepower by reducing the power required to drive these external accessories. By replacing factory pulleys with smaller diameter units, the accessories are slowed enough so that their performance does not suffer, but just enough so that more horsepower is sent to the wheels and put to the ground and also benefit from increased accessory life and also deliver better fuel economy.
Posted on: 2011/5/11 8:09
I'd be interested but the price is much too high (for my budget).
Is there an option for an aluminium version? I'd be keen on one of those I reckon.
Posted on: 2011/5/11 10:39
