(1) 2 3 »
1200s with IRS
See IRS.
Club member sssute, of MADDAT fame, fitted a conversion for his 1200 ute, using an S14 Silvia complete rear suspension narrowed almost 200 mm:
Here's food for thought. While not nearly as sophisticated as S14 suspension, 510 IRS matches up with the right places on the B110:
Posted on: 2011/5/10 9:40
Re: 1200s with IRS
From Rosewood, QLD
haha i nearly bought a 1600 rear end to do and experiment like this but chickened out, one day ill do it.
Posted on: 2011/5/10 9:48
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: 1200s with IRS
Quite a regular
From Bellville, RSA
I've installed a complete E30 BMW rear sub-frame with LSD into my B110 sedan. It's a bit to wide for the car, but I'm going to flair it in any case.
Posted on: 2011/5/10 11:22
Datsun 1200 Sedan
Re: 1200s with IRS
From Perth
I have the 1600 IRS under a 1000 coupe... unfinished... but its in there
Posted on: 2011/5/10 11:25
Re: 1200s with IRS
From Sydney
you guys must have mad skills
it looks like a great conversion.
Posted on: 2011/5/10 11:27
Re: 1200s with IRS
Not too shy to talk
looking forward to see if 1600 IRS would fit under VB110 :)
someone told me PB110 were fitted with IRS
is that true?
Posted on: 2011/5/10 18:33
Re: 1200s with IRS
PB110 comes with a live axle and 12" wheels. No IRS. Even the L16-powered PB210s had a live axle and no IRS, but at least they had 13" wheels.
Posted on: 2011/5/10 23:36
Re: 1200s with IRS
From Adelaide
Anyone finished an IRS conversion on a 1200 in Aus? Get rego? Engineering certificate?
Posted on: 2011/5/17 3:34
Re: 1200s with IRS
From Las Vegas USA
Mazda Miata / MX-5 also has a complete bolt in sub frame.......FYI. I've looked at them but as with any IRS it's a good bit of work.
Tom
Posted on: 2011/5/18 2:16
Re: 1200s with IRS
From Perth
The MX5 is alittle wide too
I think alot wide actually
I had to shorten the Xmember from the 1600 abit to fit the 1000 ... would be less work in a 1200
I'll get some pics of what I've done so far
Posted on: 2011/5/18 11:34
(1) 2 3 »
