CA18 engine mounts - what are u using?
From MOOROODUC. Victoria
I am about to go in search of the rubberised (and bolt in) engine mounts to go between the crossmember and the motor
I have found TC /TD Cortina ones for $35 each which are 35mm thick and 71mm in diameter from Burson's here in Melbourne.
Question: what has anyone else used? (the Nissan guy at the spare parts counter wanted $342 each for S13 Silvia ones ... )
Posted on: 2011/5/30 8:56
Re: CA18 engine mounts - what are u using?
From hastings,vic
land rover
ebay add
Posted on: 2011/5/30 11:13
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Thanks Jason,
But is that it? land rover or old Cortina.
Posted on: 2011/5/31 9:51
From Nyngan, nsw Australia
i payed $40 for land rover mounts or you can buy Polyeurethane Engine Mounts from Maddats for $130
Posted on: 2011/5/31 11:44
living is good,.....
From Griffith
When i was searching for these not long ago the cortina or landrover mounts were the best pick, i ended up going with the cortina ones in polyeurathane (or something like that) instead of the rubber items for extra sercurity as they werent that much dearer . From memory the silvia mounts are to high and will sit the motor to high in a 1200 causing all sorts of clearence issues.
Posted on: 2011/5/31 11:48
Not too shy to talk
From Dub-Ya Aye
U could try rotary engine mounts 12a early 13b.
Look similar to land rover mounts.
Im planning on using them.
Posted on: 2011/5/31 15:27
