Hayabusa Powered Datsun 1200 Coupe
From Trinidad and Tobago, West Indies
sorry if this is a repost, but thought it was cool and everyone would appreciate. I am really thinking about this swap, patiently waiting to see if the drive shaft from the busa gearbox holds up or if the busa gearbox explodes with the added weight. sounds AWESOME
http://www.youtube.com/watch?v=U1BVemrCx5c
http://www.youtube.com/watch?v=CfXVWlxaKwk&feature=related
Posted on: 2011/6/6 19:27
My Datsun 1200 blog
Re: Hayabusa Powered Datsun 1200 Coupe
That's awesome! Wonder what he's doing for the drive train.
Posted on: 2011/6/6 20:20
From windsor, sydney
reverse?
Posted on: 2011/6/6 21:42
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Nyngan, nsw Australia
tail shaft straight off the chain drive, using a mid universal joint....there a few car on youtube with this mod, idea
Posted on: 2011/6/6 21:48
living is good,.....
From Ringwood, Melbourne, AUS
there is another vid of it driving:
http://www.youtube.com/watch?v=tiX8A9fexDU&feature=related
Just take the countershaft sprocket, machine the teeth off it and then use it as a flange to mount your driveshaft to.
Reverse, you can either use an electric drive or something like a quaife reversing gearbox. There is a guy on PF that actually uses the original gearbox from his starlet mid mounted. Leaves it in 4th when going forward using the busa box and then changes it into reverse when necessary. Just imagine all six speeds in reverse
Posted on: 2011/6/7 1:29
Deano
it's only 1300 cc. But has 95 lb-ft torque. Which is a lot more than an A12 and more evevem than an A15.
Posted on: 2011/6/7 2:28
From Sydney,NSW
That is super cool!!
Anyone have a brand or pictures of the electric reverse??
Posted on: 2011/6/7 2:32
I think they just fit a starter type motor and drive it off a ringgear somewhere on the drivetrain, haven't seen any pics but would have to be somewhere, is used in a lot of bike engined kit cars.
here is one for a chain drive diff:
http://www.westgarage.co.uk/news/files/electricreverse.jpg
Posted on: 2011/6/7 2:50
Deano
From Sydney, NSW, 2036
I like bike engined cars..
the dual gearbox idea is a neat way to get reverse.. at 1:1 in 4th would you expect much driveline loss?
Cheers
Ed
Posted on: 2011/6/7 2:59
81 Datsun ute
You wouldn't expect much as you are only turning the layshaft freely but I guess it would be some. You could even remove the non used gears if you wanted, would remove any extra points of failure and possibly some parsitic drag.
I guess the biggest downfall would be the added weight and complexity of gear shift linkage..
Posted on: 2011/6/7 3:17
Deano
