« 1 (2)
Re: Hayabusa Powered Datsun 1200 Coupe
If you go through the trouble of fitting a hayabusa
engine then you could just use a modified transfer box
to run the high rear in reverse.
It would be cheaper than a quaife
Posted on: 2011/6/7 3:25
From Trinidad and Tobago, West Indies
i have been researching this allot
easy way to get reverse... add large electric starter motor from diesel truck to gear welded to rear drive shaft, been done...
hard way, remove the hayabusa gears from the gear box housing, create a custom output shaft to go into any rwd gearbox you want.. http://www.motoiq.com/magazine_articl ... hell-we-are-thinking.aspx
i have seen 600hp hayabusa engines (turbo charged)
the main thing is from what i have read, the hayabusa clutch is a reduced ratio clutch (6:1 or something), so you gotta replace it with one that is:
a) strong enough to handle the increased weight
b) one that doesnt have a reduction ratio
I am interested to see this thing actually run flat out, make some hard launched and skids.. before i get my hopes up, but some guys with MK1 golfs and Lotus 7's etc use this swap allot with great results..
Posted on: 2011/6/7 5:19
My Datsun 1200 blog
here is one of many ToyoBusa's (Starlet / Hayabusa)
http://www.youtube.com/watch?v=afLBp_3Md-A&feature=related
its using the stock Hayabusa gearbox with a vr4 drive shaft on the drive sprocket and going to a toyota gearbox with only 4th gear and reverse.. so you leave it in 4th and shift with the busa box and then put it in neutral with the busa box and then engage reverse with the toyota box, genius!
Posted on: 2011/6/7 5:37
My Datsun 1200 blog
Not too shy to talk
From vic
anyone got any vids of it burning rubber??
Posted on: 2011/6/7 8:04
we've already got a thread on motorcycle motors
http://datsun1200.com/modules/newbb/v ... =ASC&type=&mode=0&start=0
imo i don't think you'll ever be able to "launch hard" if its not the clutch that lets go it will be something else, and you only use it to get going.
Posted on: 2011/6/7 8:27
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From ACT Aus
well you're not getting rego in australia so why do you need reverse?
Posted on: 2011/6/7 11:03
unfamilia wrote:
You have bump stops? Your soft
From Sydney
why can't it be registered?
Posted on: 2011/6/7 11:09
From newcastle, NSW
Now thats cool!
That would be awesome conversion!
i have a b10 in mind!
Posted on: 2011/6/7 11:37
From Sydney, Australia
It looks like fun..
http://www.youtube.com/watch?v=tiX8A9fexDU
Posted on: 2011/6/7 12:33
From ACT Aus
true haha
would definitely like to see someone try
Posted on: 2011/6/7 14:02
« 1 (2)
