B310 springs
From Brisbane Qld
Hay who can tell why would pay more for king springs when i can get cheaper ones from auto barn
for my B310 sunny sedan how much better are the king springs?????
Posted on: 2011/6/14 8:36
Re: B310 springs
From Brisbane Qld
Bump hasent anybody got a anser for me????
Posted on: 2011/6/23 4:02
Re: B310 springs
From vic
well the answer is preety simple i guess you get what you pay for!
so what brand is the ones in autobarn?
somtimes cheaper might not be bad i think high branded components are overpriced while a cheaper brand will perform the same for cheaper but this isnt true all the time!
Posted on: 2011/6/23 11:39
Re: B310 springs
From Adelaide
Don't know with this specific question but often cheaper means less quality control so it's a bit of a gamble. Often you're paying for the engineering and quality assurance with the brand as if they sell a dodgy set of springs it hurts them a lot. No name brands have nothing to lose so there's the gamble.
Posted on: 2011/6/23 12:40
Re: B310 springs
From Brisbane Qld
The springs at auto barn are GABRIEL @ $145 aset and the shocks thay list are front MONROE @211 apair rear shocks GABRIEL @ $76
Posted on: 2011/6/23 13:07
Re: B310 springs
I got kings in mine (B310) and when I swap it over to another car I'll cut 1 coil off both the fronts and back. Using standard lowering ones lowers it but #OOPS# all and just that 1 coil more would make it look so much tuffer.
Posted on: 2011/6/23 13:08
Re: B310 springs
Gabriel is a reasonable brand and I dont see it been worse than King springs.
Id go for the Gabriel and if needed lower then just have them heated professionally
at most places for cheap. Only issue with non factory springs is the car could sit
higher than required.
Posted on: 2011/6/23 13:53
Re: B310 springs
From Brisbane Qld
Yes thanks guys all verey help full.
I all so have some mags i got for 1200sedan but now
its sold iam hopeing thay would be ok for the B310
thay are 14x6 jj has been stamped on the inside of the rims.
What i want to know is that a good offset? for the sunny and would
anybody recomend some good tyers that wont break the bank?
and be leagl in qld iam not planing to lower the car that much and would perfer comfort.
Posted on: 2011/6/24 1:38
Re: B310 springs
From Brisbane Qld
BUMP
Posted on: 2011/6/25 7:35
Re: B310 springs
From Brisbane Qld
BUMP
Posted on: 2011/6/30 23:36
