Browsing this Thread:
1 Anonymous Users
Re: tommo's ca coupe |
From hastings,vic
will check volume and let u no ben i think it needs to hold 1000mls got my oil cooler today,bit of bling asked local hose man today that was making me some brake lines for a 1200 ute $135 for three custom in rubber(needed today,ripco couldnt supply till wensday next week) how much for 1mt of -10 hose same as cooler. $75 per mt i brought cooler with 3x1mt peaces of hose as seen in pic cooler,fitting sand filter mount ect for $129 will post some pics of it fitted soon
oil cooler.jpg (121.31 KB)
Posted on: 2011/6/10 10:11
taking up room at home 3 now 2 1200 sedans,3 now 2 1200 coupes,3 now 2 1200 utes 1 1000 wagon,2 s13 silvia's,tranzit tray hzj75 cruzer tray(for sale) and allways changing
From SE Melbourne
Oil cooler looks good too!
The CAMS rules for a oil catch can are.... "15. if fitted with any crankcase breather discharging to the atmosphere, each breather be vented into a catch tank of minimum capacity of two litres for engines up to 2000cc or three litres for over 2000cc. Regulations for competitions on unsealed surfaces may waive this requirement;"
I'd probably use the space you were going to use for the wiper washer additional to add up to close to 2L
Posted on: 2011/6/10 10:37
Mildman, Datsunless
Is all that in the pic for 129 smackos?? if so, can you get it all in plain alloy finish?
As shooter pointed out ingenious use of radiator heat! really moving fast with this project
Posted on: 2011/6/10 10:58
From hastings,vic
cooler fitted and tanks fitted
Posted on: 2011/6/10 14:23
Why in the middle and not offset to one side for full cooling effect? Disruption to air flow across core of ic and rad?
How much are new brake lines for a 1200? Steel not braided?
Posted on: 2011/6/10 15:26
From hastings,vic
brake lines braided about $80 each
Posted on: 2011/6/10 23:33
"i brought cooler with 3x1mt peaces of hose cooler,fitting sand filter mount ect for $129"
where from? thats cheap!!!
Posted on: 2011/6/10 23:52
From hastings,vic
EBAY if u look hard enough u will find looked under oil cooler kits it was from malaysia oil cooler ebay
Posted on: 2011/6/10 23:58
From hastings,vic
done a little more made some alloy covers to clean things up and some guages to no wot going on when under the bonnet cur off top grill mount and made a new one,looks alot better now no gaps
Posted on: 2011/6/16 6:56
From hastings,vic
couple of pics of tonights work moded lower front panel to fit oil cooler and to let more air in and made shore the front guards all lined up
Posted on: 2011/6/16 14:47
