Anyone done this?
From Nations Capital, Australia
"to keep the nice old engine in good shape with today's ultra dry eco fuels: Use 1:100 API TC two stroke oil/fuel mix as a regular driving fuel, that keeps the old fuel system gaskets, rubber parts, alloy parts etc... and cast iron metal surfaces of the vintage engines in excellent shape... And it also lubricates the valves and upper piston regions. Most Porsche vintage owners in Germany do so :) Also keeps carbs and tank clean and rust free."
Cut and pasted from you tube comments. Anyone tried this? Peoples thoughts?
Posted on: 2011/7/13 1:43
Re: Anyone done this?
From Malaysia
wow, use 2T oil in 4T engine? i thought 2T oil is poisonous for 4T system.
Posted on: 2011/7/13 2:27
Not sure.
Posted on: 2011/7/13 10:40
dunno about piston motor's but when i owned my 1200 rotor i used 2 stroke oil in the fuel as a pre-mix.
Posted on: 2011/7/13 10:43
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From windsor, sydney
As lethal-john says 2stroke in a rotor is common ,and as long as you dont have a catalitic converter exhaust a splash of 2stroke in the fuel is a good thing for a older engine that was designed for leaded fuel.
Posted on: 2011/7/14 21:49
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Las Vegas USA
Sure I put 2 stoke oil in almost every vehicle in the garage..................76 YZ125C, 77 CR125 Elsinore, 84 KT100 Kart, KTM300EXC, 01 YZ125 and Blata pocket bike. Only the coupe and Honda 90 go without.
Ok on a serious note I have heard of people doing this, once new some poeple who about to run out of gas at Lake Mead put in 100-1 premix from the boat dock............the car ran fined but smoked a bit more.
Besides there nothing like the smell of bean oil in the morning.
Tom
Posted on: 2011/7/15 1:20
From Ringwood, Melbourne, AUS
Yep, have heard of people doing this but only with very minimal amounts of 2T oil, too much just creates smoke and can even affect A/F in excessive amounts.
The only thing better than the smell of a ring-a-ding in the morning is av-gas.. mm mmm
Posted on: 2011/7/15 3:20
Deano
