Coolant advice wanted.
From Perth WA AUS
I have filled my system with Tectaloy 90 plus heavy duty coolant about 6 months ago and after pulling off my thermostat housing yesterday I noticed some minor corrosion building up, Is there a better product to use or is my cars lack of use the problem?
Posted on: 2011/7/23 13:47
Datsun 1200 2Dr sedan.
Re: Coolant advice wanted.
Probably lack of use and crap metal composition on the thermOstat. I had first lot of tectaloy go cloudy after 1 month. Dropped it and used same type and has been fine. Just a weekly start to temp if I haven't driven it keeps it ok
Posted on: 2011/7/23 14:09
From Perth WA AUS
Thanks mate, I'll dump it, refill and see how it goes :)
Posted on: 2011/7/23 14:52
That's from my experience, replace the thermostat while it's out and coroded though. I'm thinking tectaloy have either stoped their standards or chemicals have changed
Posted on: 2011/7/23 15:05
I use Nulon Red since I found out that many places dont
warranty anything with Tectalloy. Ive used Tectalloy in
previous cars with no dramas but heard several owners
had thermostats issues similar to Micks description.
I only found out about the red when I went to buy some
as recommended by MBenz manuals but fell over backwards
when I found the price and went Nulon Red instead.
Maybe someone with more insight can dime in.
Posted on: 2011/7/23 15:42
Hey levey,
I can't reccomend enough the 'toyota red coolant'.You won't be dissapointed!.Its amazing how many oem products are better than aftermarket ones.
Cheers
Posted on: 2011/7/24 3:19
From Coondle, WA Australia
Ive heard good things about the toyota red coolant as well.
but for the budget concious person, the Castrol concentrate in a can is the best cheap option from my experience.
ive used it in a variety of cars and never had a problem. Its not picky about mixture rates (like technaloy) and at about $10 a can, its cheap as, and you can carry a spare in the boot without taking all your space.
Posted on: 2011/7/24 3:33
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Its fitting Toyota followed Mercedes with their own red coolant.
The Germans and Japanese focus on quality, durability etc
Posted on: 2011/7/24 3:43
Some quality products like the toyota red coolant actually work out to save you more in the long run. Instead of having to later replace corroded radiators, water pumps,thermostats,heater pipes etc...
Better safe than sorry
reuby,
from your experiences i would say the castrol you mentioned is a quality product even though not expensive.whats the lifespan of that particular coolant?thanks just to get a comparison to other coolants lifespans.
Posted on: 2011/7/24 4:03
Im not sure on life span of the product, but its this product
supercrap auto reference
castrol radiator stuff
Castol Australia
Castol australia website
the one in the bottom right corner of the four pictured
In the past, I have had to drop the radiator coolant before it wears out i spose since i am always tinkering so it never wears out on me, but at $5.00 a can its not expensive to replace.
Posted on: 2011/7/24 5:06
