Rocker arm assemblys
From Christchurch NZ
Are the complete rocker shaft/arm assemblys the same from a12/14/15/gx?
The reason I ask is because Im having a gx head tickled up(guides, seats, hardness tst , pressure tested etc) and when I bought it ($20) it didnt come with a rocker shaft assembly. I have a few spares off other donks but is there a difference? I know there are trick rocker arms but Im not concerned with that .
Posted on: 2004/2/17 7:36
Forced Induction!
Re: Rocker arm assemblys
From Forsby Finland
I have read somewhere that the rockerarmratio is 1:1,4 on A10/12 and 1:1,5 on A14/15 but I have tried to measure the difference several time without noticing the difference, maybe the different ratio is due to different geometry in someway.
I belive that you can use the rockershaft/arms from any Datsun A-series engine!
Posted on: 2004/2/17 9:16
I am building a mean Datsun E10 racer , a15 turbocharged engine, aiming for 280hp....
From durban, south africa
I've used a A-14 rocker assy on my A-12 with no prob at all.
Posted on: 2004/2/17 10:42
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From Auckland N.Z
I put a new cam in my a12 and while doing this i had new dubble valve springs put in. The guy who did the valve springs said my rocker shaft was being starved of oil and was close to seizing. He showed me the wear and said it was common in the a series motors and it was easily fixed by closing the top of the oil hole and scribing/ cutting a cross over the bottom oil hole. this forces the oil to rise up the sides and totally cover the rocker shaft in oil. It cost $30 and seams to be working a treat.
verry worth it.
Posted on: 2004/2/17 11:35
