« 1 (2) 3 4 5 ... 7 »
Re: 1400 UTE Rebuild
Quite a regular
From South-Africa
Had some fun fixing the rust so that is luckily done now !!!!!! Here are so pics!!!!!
jpg  DSC00003.JPG (128.22 KB)
14784_4e49210ce86da.jpg 640X480 px
jpg  DSC00004.JPG (164.16 KB)
14784_4e492119a8813.jpg 640X480 px
jpg  DSC00005.JPG (158.66 KB)
14784_4e4921262848d.jpg 640X480 px
jpg  DSC00006.JPG (159.32 KB)
14784_4e4921343dca4.jpg 640X480 px
jpg  DSC00007.JPG (131.53 KB)
14784_4e492140cbc39.jpg 640X480 px
Posted on: 2011/8/15 14:38
Lifes A journey Enjoy the Ride
Quite a regular
From South-Africa
It finally feels like I am getting somewhere after all I have been busy with this build since beginning last year!!!!!!!!! It looks a lot better now with a coat of primer on!!!!! Will get painted this weekend then comes the fun part putting back everything without damaging the new paint job!! Assembling the engine and the rest of the Ute!!!!!!
jpg  SDC11377.JPG (199.55 KB)
14784_4e4a32b43c4c5.jpg 640X480 px
jpg  SDC11378.JPG (198.34 KB)
14784_4e4a32c54a820.jpg 640X480 px
jpg  SDC11380.JPG (118.93 KB)
14784_4e4a331ef1174.jpg 448X336 px
jpg  SDC11379.JPG (118.31 KB)
14784_4e4a332ccba7d.jpg 448X336 px
jpg  SDC11382.JPG (192.00 KB)
14784_4e4a33501c195.jpg 640X480 px
jpg  SDC11383.JPG (174.94 KB)
14784_4e4a3380c05e9.jpg 640X480 px
jpg  SDC11384.JPG (175.74 KB)
14784_4e4a33d284d69.jpg 538X480 px
Posted on: 2011/8/16 10:09
Quite a regular
From South-Africa
Hi guys can you please advise me on the following?
How much do you lighten the standard flywheel?
How do you increase your oil pressure?
Is it helpfull performance wise to knife edge the crank?
Is a 280 degree cam to wild for daily use ?
Can you still use the standard push rods and cam followers?
jpg  SDC11386.JPG (119.49 KB)
14784_4e4cef1c3af8e.jpg 448X336 px
jpg  SDC11387.JPG (114.48 KB)
14784_4e4cef2c6b59a.jpg 448X336 px
jpg  SDC11388.JPG (128.36 KB)
14784_4e4cef370c6a4.jpg 448X336 px
jpg  SDC11393.JPG (143.95 KB)
14784_4e4cef48a306a.jpg 448X336 px
jpg  SDC11394.JPG (116.45 KB)
14784_4e4cef536cdbf.jpg 448X336 px
jpg  SDC11395.JPG (112.97 KB)
14784_4e4cef5f5a91c.jpg 448X336 px
Posted on: 2011/8/18 11:55
From Cape Town, South Africa
Damn, it seems that I'm missing and only today discovering all the South African build threads.
GTR Damn you for stating the fact that you will be starting to but it together as I still have to spray.
Glad to see you are keeping it clean, with no big ass spoilers and sideskirts.
If you intend on using it as a daily, knife edge is not worth itm rather get the motor balanced, 280 cam is wild, no gains with standard carb. I use the standard followers and push rods on our race motor.
Flywheel, again what will the use be, I use a 3.8kg wheel on the motor, crap to pull away, but on a balanced motor, it makes for a rather quick revving toy.
Why do you want to up the oil pressure?
Posted on: 2011/8/18 12:14
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Oh tell me more about the vehicle in your avatar???
Posted on: 2011/8/18 12:17
www.race-tech.co.za
Quite a regular
From South-Africa
Well some say when you put in a performance cam you need to increase your oil pressure to prevent engine failure!!! I am going to run two 40 SD carburettors with the 280 cam will it idle with that cam?? Semi-Racing and daily use when they balance the motor what precisely do they do?? My avatar is actually a other guys creation which I just copied but it is a real bakkie that does exist!!
3.8 motor with turbo auto box and hilux transfer case on hilux diffs, and no chassis but the original Nissan shell that’s just re-enforced
jpg  1400 4x4 1.jpg (48.15 KB)
14784_4e4d0ec06b75a.jpg 640X480 px
jpg  1400 4x4 2.jpg (47.83 KB)
14784_4e4d0ec745dd3.jpg 640X480 px
jpg  1400 4x4 3.jpg (40.05 KB)
14784_4e4d0ecf17407.jpg 640X480 px
jpg  1400 4x4 4.jpg (43.59 KB)
14784_4e4d0ed8534da.jpg 640X480 px
jpg  1400 4x4 5.jpg (40.53 KB)
14784_4e4d0ee60865e.jpg 640X480 px
jpg  1400 4x4 6.jpg (45.41 KB)
14784_4e4d0ef171534.jpg 640X480 px
Posted on: 2011/8/18 14:09
From Sydney, NSW, 2036
I think rather than up your "oil pressure", you prob want higher flow. (hi vol). I know from building other engines this requires a pump with different impellers to achieve this. I dont think a cam change would cause oiling issues, but probably using it constant hi revs may starve your top end for oil... Another thing we did with the Holden V8's was to debur the block and all the oil gallery holes inside so all the oil would flow around better. Not too familiar with the Datsun engines but these sort of mods are free and may negate the use of aftermarket pumps.
Cheers Ed
Posted on: 2011/8/19 1:08
81 Datsun ute
Quite a regular
From South-Africa
Thanks guys for the advice will definitely help to get the 1400 going a bit faster then it normally did. I have 2 40 delortos side draughts will they work nicely with the 276 cam and lighten flywheel with the balanced motor???? Can the standard 4 speed gearbox and diff take the punishment?
Posted on: 2011/8/23 15:03
That is for some other brands of engines that are not as good as Datsun A-series. The A-series does not require increased pressure even for racing.
Posted on: 2011/8/23 19:35
From Coondle, WA Australia
Off topic i know but...
that orange bakkie is awsome!!!
That really does look the part. How is the body flex with that considering it has no chassis?
Posted on: 2011/8/23 23:46
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
