Brake Fluid Hose?????
From Perth
Hey guys,
I have mounted remote reservoirs for my brake set-up, can anyone advise me of what type of hose to use from the reservoir to the mastercylinder? Size must be 5/16.
Many thanks.
Posted on: 2004/2/23 4:59
Re: Brake Fluid Hose?????
From Sydney, Australia
Not heater hose, I expect fuel hose (low pressure) will do the job. The reservoir to mastercylinder is low pressure, so it's just a matter of finding a hose whose material doesn't dissolve in brake fluid.
Chris.
Posted on: 2004/2/23 6:23
From Perth
So you think Fuel hose will be ok? I thought this would be ok also (it can handle AVGAS!) Some people seem to think it will perish though?
One place quoted me some fancy Hose at $40 per metre! I only need 2 metres all together, but still, that's bloody expensive!
Posted on: 2004/2/23 9:08
From Perth
Don't use normal fuel hose......it sweats
Post answered in Ozdat forum
Posted on: 2004/2/23 11:12
From Perth
Thanks dude!
Posted on: 2004/2/23 22:56
From Canberra
"Don't use normal fuel hose......it sweats"
This is true.....however you should be OK using EFI hose because it is designed to take a higher pressure. I have the stuff running inside the cabin in my rally car and it does not sweat, even with a good dose of race fuels.
Buy EFI fuel hose and it will do the job.
Posted on: 2004/2/23 23:03
