« 1 (2)
Re: very loud air horn information needed.
From Perth
Train horns are scheduled for the Cadillac... with the airbag install... one day
Posted on: 2011/9/29 13:54
From Coondle, WA Australia
My exhaust is loud enough without fitting trumpts, although that does sound intresting.
It seems that proper air horns are the only way forward. Time to get the design and engineering boots on.
Bescides, a resivour of compressed air tank for the pootrol wouldnt be that bad anyways.
Posted on: 2011/9/29 23:28
Edited by reuby_tuesday on 2011/9/30 7:19:50
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
I had to disconnect mine for RWC, then found out they were rooted anyway :( the stock Hilux horn is embarrassingly weak so watch finger.
Ive seriously considered mounting them in the 1k the amount of times I have been nearly run into by oblivious barge (SUV) drivers but If I ever get any hassle about the noise of my exhaust, im going to aim for the "its a safety feature" angle...either that or get a little orange flag like the cyclists have :/
Posted on: 2011/9/30 2:35
From Albany, Perth Australia
the horn i gave you not load enough reuby hahaha
Posted on: 2011/9/30 11:03
1200 Smerf Mobile
could just strap nige to the roof and hear his screams of pleasure..... thats enough to scare every one in wa off the roads.
just the thought of the starp made him dribble a little in his undies with excitement
Posted on: 2011/9/30 12:34
From Perth WA AUS
We all know what gives you a horn Mik!
Posted on: 2011/9/30 13:56
Datsun 1200 2Dr sedan.
Yep, same as you, hard wood
Posted on: 2011/9/30 14:18
It helped Brett, thanks for that. Ive got it wired in with the original horn, which is about half the size of the one you gave me. Its only just loud enough to hear it over the engine noise. Ill get it back to you once I fit the new air horns since I know that you spent some time fixing it up. It works perfectly.
Now why doesent it surprise me that the thread turned to mud once Levey and Unfamilia turn up. It was only a matter of time till the gutter folk turned up and discussed my horns. shhessh!!!
Posted on: 2011/9/30 23:16
From Perth WA AUS
Posted on: 2011/10/1 8:38
At least I haven't touched your horn- I'm sure same can't be said bout levey after the rally couple weeks ago.
Posted on: 2011/10/1 9:03
« 1 (2)
