how to wire ca18det
From Trinidad
I have a ca18det in my datsun 1200 and wanted to know how to wire the ecu etc? I mean what colour wires from the harness goes to the ignition switch via a relay
Posted on: 2011/10/26 13:58
Re: how to wire ca18det
From MOOROODUC. Victoria
Posted on: 2011/10/26 23:26
From Trinidad
the engine starting but it is running really rich either that or the spark is weak. how to resolve this issue?
Posted on: 2011/10/27 23:46
From Sydney, Australia
Did you fiddle with black box thing on throttle body? This can do that.
Posted on: 2011/10/28 8:27
From Trinidad
the throttle position sensor? no I didn't move it
Posted on: 2011/10/29 2:19
Most people straighten it up, and the results in the ECU thinking it's off idle and add more fuel like a accellerator pump jet.. Also, chipped ECUs will run like crap too. There are too many floating around these days. Unlikely to be weak spark with 4 coils, unless all 4 are cooked. Check your earths and measure the 12V at the coils while engine is running. Could also be old and leaky injectors.
Posted on: 2011/10/29 12:01
From Trinidad
I checked the coil pack for battery voltage.. good
I checked for continuity on ground circuit .... good
I removed all injectors and cleaned them .... doubt all 4 are leaking
changed the plugs again last night and the car ran like a beast for about half an hour and then started to run on 3 cylinders.. pulled all the plugs and all were black and fowled... any other advice? also someone was telling me that it could be the air flow sensor... I checked it against the factory service manual and it's within specifications ... running out of ideas here guys
Posted on: 2011/10/30 20:55
From Melbourne, Australia
perhaps the ecu still thinks the engine is cool and continues to dump extra fuel? problem with temp sensor?
Posted on: 2011/10/30 23:41
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
Maybe check the ecu for fault codes.
Posted on: 2011/10/31 4:44
From Brisbane, QLD
Check the temp sender for the ecu. It should be 70-90ohms at 60deg and 21-24ohms at 100deg. or code 13 should show in the ecu if it is faulty.
Posted on: 2011/10/31 8:14
