Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
help needed to wire tacho!
a12datto120y
Posted on: 2011/10/28 5:29
hi just needed to know were these wires go for a 120y tacho it originaly came with a clock.
#2
Re: help needed to wire tacho!
datsa73
Posted on: 2011/10/28 6:29
Just plug and go. Your 120y should have the standard wire harness for the tach under the dash. Mine did when I found a tach for it. Just look for the wires.
#3
a12datto120y
Posted on: 2011/10/28 7:25
Nice i will check it out.
Thanks!
#4
DISMO
Posted on: 2011/10/28 8:16
just double check where thos black/white wires go because how the 120y and 1200 tacho's pick their signal up is from the coil current in series or going through them instead of just being picked up off neg coil like most modern tacho's. but like whats just been said shouldnt be able to go wrong with standard factory wires.
#5
datsa73
Posted on: 2011/10/28 11:19
Should just plug in. I had that exact same tach for my B210 here in the states. Just look under the dash. You should see the terminals.
#6
Shifty
Posted on: 2011/10/28 23:16
wish it was that easy on mine :(
never could find anyone to tell me how to wire up the stock tacho, to my haltech ca18 :( You can view topic.
