waste gate
Quite a regular
From Whyalla
hello every 1 iam in need of an external waste gate the cheepest 1 i can find, so can turbo my 1000 ute. any help would be great
Posted on: 2004/3/5 2:09
Re: waste gate
why do you need and external one?
what engine are you running and what turbo?
Posted on: 2004/3/5 4:22
Re: waste gate
From Warwick, QLD
yeah what turbo are you running?? Only big turbo's need external wastegating.
Cheers
Damo
Posted on: 2004/3/5 5:11
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: waste gate
Only turbo's with no internal wastegate need external wastegating!
Or where the internal one is too small
Posted on: 2004/3/5 5:22
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Re: waste gate
From Christchurch NZ
Waste g ates are deadweight! Take it off and I guarentee your car will be faster, maybe not so long life but definatley faster.
(lol)
Posted on: 2004/3/5 5:39
Forced Induction!
Re: waste gate
From Warwick, QLD
yeah don't run a waste gate but if you have a aftermarket ECU then just set the rev limiter lower that way you don't overboost.
(Please don't actually try that, it was my attempt at a joke)
Cheers
Damo
Posted on: 2004/3/5 6:11
Team NEW SKOOL
Re: waste gate
Quite a regular
From Whyalla
the turbo im using is a KKK K-36 with no internal waste gate, and the motor is a a12. Its ok i cant be stuffed wasting a heap of money on a waste gate so im making my own set up, im making a custom waste gate out of a ball valve so i can fully adjust it.. has any 1 ever see nthis done ???? thank you
Posted on: 2004/3/6 11:30
Re: waste gate
From Sydney, Australia
Dudes...lets stop the crap...and get terms straight, and start to build a plan.
Wastegate = Mechanism for slowing down turbo speed by diverting engine exhaust gas around the exhaust wheel on the turbo.
Blow off valve = Mechanism for venting compressed intake charge to atmosphere or back to the intake of the turbo. This keeps the speed of the turbo up.
Boost Adjustment valve = valve for bleeding off plenum pressure to make the wastegate actuator work higher in the boost range, resulting in higher boost.
Answer about using a ballvalve..NO WAY. The cost of a ball valve that could cope with 1000degree exhaust temperatures would be difficult to find and not appropriate for the job.
Boost is the ability of a a turbo to push more air than an engine can use. When talking about "turning up the boost" you are effectively allowing the turbo to spin faster.
Get a turbo with an integral wastegate. Finding a cheap external wastegate for that turbo will be almost impossible. (If it is infact a non-integral wastegate model).
Chris
Posted on: 2004/3/6 12:02
