(1) 2 3 »
How to Choose and Tune Weber Carurettors : Basic Understanding
Searched forum but couldn't find too much detail on weber tuning information.Searched google and found some interesting links to tuning and choosing weber dcoe carburettors.
Links:
http://7faq.com/owbase/ow.asp?HowDoI%2FTuneWeberCarburettors
http://www.pumaracing.co.uk/Chokes.htm
http://www.gglotus.org/ggtech/carbjetting/carbjet1.htm
Even though no two engines will produce the exact hp could some of the forum members that are using twins webers be kind enough to post up their dyno hp and torque figures and list of modifications of their setups etc for their NA motors and especially the A series.This would help some of us who haven't undertaken the process of choosing the right size webers for different applications.
quote from first link,
A large venturi may give more power right at the top end of the power band, but will give this at the expense of lower RPM tractability. Only a circuit racer will benefit from this sort of compromise, on a road car, driveability is much more important. 95 percent of the time, a road engine is nowhere near its peak power, but is near its peak torque for 75 percent of the time. It is much more important therefore to select the main venturi for best driveability, once the venturi size has been selected, then the appropriate carburettor size can be arrived at.
From the links, expected bhp figures could help in choosing the right main venturi sizes.And tuning has been "stressed out" to be very important and things like the wrong choke sizes etc can even affect engine life.(running very rich,oil leaks).
so any dyno sheets or links to some would provide valuable data as to how a similarly modified a series might run.
The last link was also very informative on how to tune.i.e using a portable exhaust gas analyzer like one sold by gunsons and how to try and evaluate the data you get from its mixture map.Going to a dynamometer tuner etc.
Cheers
Posted on: 2011/11/21 1:07
Re: How to Choose and Tune Weber Carurettors : Basic Understanding
link to New Gunson Gastester exhaust gas analyzer tester for sale on ebay
http://www.ebay.com.au/itm/Gunson-Gastester-exhaust-gas-analyzer-tester-/280681199112#ht_2512wt_1139
i'll be definately be buying one of this units in the future.Are there any local dealers of this units in oz?
cheers
Posted on: 2011/11/21 1:26
From Sydney
The Gunson-Gastester product im sure is good, but it is hard to beat the AEM wideband air fuel ratio gauge. they are compact and 12V powered so you can have it mounted in your car for real time AFR measurements, for those without a dyno.
AEM wideband
One good rule of thumb with webers is "if in doubt with the choice of the calibrated parts, choose the smaller one" Many a time have I seen webers with chokes way to big that gas speed are near non existent and idle and main jets that are too big for the application.
Posted on: 2011/11/21 3:00
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Very true, if in doubt choose bit smaller
Thanks for that link AEM wideband air fuel ratio gauge benny.I will research more into it.How would you interpret from the AEM wideband air fuel ratio gauge which "better" size chokes to use across the whole rpm range?
Posted on: 2011/11/21 3:13
The weber book has what you're looking -- how to choose the correct carburetor size.
Here's the chart from the book. I recommend you buy the book for the explanations.
Carburetor Sizing
For a single carburetor barrel (bore) per cylinder, rather than multiple carbs or bore feeding all cylinder via a plenum, use this chart:
* 6000-RPM A12: dual 40s are a bit large, but in reality seem to work OK if you fit the smallest venturis.
* 8000 RPM A12, calling for 36mm venturis per the chart, you could use either 40s or 45s.
Posted on: 2011/11/21 3:44
From Ringwood, Melbourne, AUS
PM sent
Posted on: 2011/11/21 4:34
Deano
From Sydney
The gauge has the ability to output data [A/F ratios to a pc]. this can be cross referenced against rpm to indicate lean or rich at particular conditions. Having an understanding on how a sidedraught carb operates is always an advantage as well.
Posted on: 2011/11/21 5:07
1970 KB10 Coupe
S13 caliper b...
From Near Bundaberg QLD
This book?
http://www.ebay.com.au/itm/Build-Tune ... ction&hash=item3cbeb9f22c
Posted on: 2011/11/21 7:57
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
The one I referred to is 'Weber Carburetors Owners Workshop Manual' by Haynes UK.
I borrowed this excellent book from the library.
Posted on: 2011/11/21 8:08
thanks ssskiwi ,benny n ddgonzal.I will definately buy that book.thanks for links guys.that info is very appreciated.
Posted on: 2011/11/21 8:54
(1) 2 3 »
