(1) 2 3 »
L26 in a '71 1200?
has any one ever tried to put a '75 L26 260z motor in a '72 1200 coupe? ive got a guy who is basically giving me 2 L26 motors w/ triple webbers! if its too much work ill
just keep my slightly stock motor in...
Posted on: 2001/8/10 12:55
Re: L26 in a '71 1200?
From Finland
It
Posted on: 2001/8/10 1:05
thx... be kinda cool to have a z motor tho huh?
Posted on: 2001/8/10 1:50
dash replacement
Not too shy to talk
Don't get me wrong, I love the 1200 coupe dash, but was wondering if there are others that can be easily modified
to fit in?
plus.....
I love the look of those blue luminated dials, but i think they are only for newer models, anyone know
otherwise??
Michael
Posted on: 2001/8/10 2:18
Re: dash replacement
From Sydney
I think a 120y dash can fit. I dont know how easy but, could be a bit of butchering to make it fit. I wouldnt bother anyway, there ugly. If u want those blue luminated dails im pretty sure
u could buy the gauges seperate from Autometer or Rocket, then use a coupe dash and rip out the old gauges and make them fit. This is what im planing to do so i still have the origanal
dash with cool new gauges. Cya
Scott
Davo
Posted on: 2001/8/10 4:57
From Castro Valley,CA USA
I've butchered mine up a little. Added an aluminum insert and filled it with more gauges than i know what to do with. i try
to add a picture
Angelo
Posted on: 2001/8/10 8:01
From Fort Worth, Texas, USA
I'm going through the same fact finding session with an L-28 in a '71 510 wagon. Everyone I have talked to has said that the six is too long for the 510 engine bay so I would assume that
MAJOR surgery would be needed to fit in a 1200. If you were to cut out the firewall and transmission tunnel you could probably get it in the car. I'd bet that the shifter would wind up in
the back seat though. I'd try to find another vehicle that could use the "free" engines rather than cut up a 1200 that much. You are right though, a straight six would be a hoot! Have a
day. Tim
Posted on: 2001/8/10 9:46
Quite a regular
Tim,
That's correct - the 1200's enigne bay is smaller than the 510's by a fair margin. I'm putting an SR20DET into my 1200 and it's a VERY TIGHT squeeze. Like the 510, the VG30 would be an
easier fit.
Even as it is, the SR20 and trans has the shifter about 6" back from the normal location. There is a combiation of SR/KA gearboxes that alleviates this somewhat and puts the shifter in
near-stock location. Unknown if this type of combo can be done for an L-motor.
Dave Lum
'72 1200 getting SR20DET
'71 1600 w/ VG30DE
www.datsuns.com
Posted on: 2001/8/10 10:28
Is this overkill? I put a picture of my dash in Members Datsuns.
The foam cover was removed and the metal trimmed to fit around the roll cage. This thing will fit right over the front horizontal bar.
Anyways, this aluminum panel fits where the stock plastic insert was. If i wire this up right, i will still be able to pull this panel off without pulling
the hole dash.
Posted on: 2001/8/10 7:33
From Invercargill, New Zealand
Mate that dash rocks - way awesome.
Posted on: 2001/8/10 9:31
(1) 2 3 »
