Browsing this Thread:   3 Anonymous Users
« 1 (2)
Re: A15 cuts out when driving
Yes, it could be the coil
Yes, it could be the crane igntion
Agreed, the easiest way to test it to substitue a stock coil & distributor.
Posted on: 2011/12/11 21:35
Edited by ddgonzal on 2011/12/11 21:55:23
Check the float bowls and floats. On the webers this has been problem on my 1200. The fuel pressure will still read 3 psi, your pick-up is before the carbs. The next thing is check your coil. we went with the HPX system and it works great. also check your grounds, you may have one that is bad.
Hope this helps
John
Posted on: 2011/12/12 0:30
From mandurah
yea i check the fuel float levels ,it stopped and i killed the fuel pump straight away ,then i pulled the carbs apart and the bowls werent empty ,and i checked the floats hadnt bent or anything
and i bought a new mec717 bosch coil today and warmed it up ,then it started trying to stall then when ide give it some throttle it would blow flames out the exhaust ,so i think the crane fireball has #OOPS# itself or the pick up in the dizzy is getting hot ,even though its optical trigger so heat shouldnt affect the signal
Posted on: 2011/12/12 12:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
not lighting the matches quick enough.stay off the piss. haaahaaa
Posted on: 2011/12/12 13:08
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From mandurah
haha NO!
Posted on: 2011/12/12 14:58
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From perth airport
did you try sr20 ?
Posted on: 2011/12/12 22:36
perth airport parking
Datsun 1200 ute A14
From mandurah
Thats gay jordy ,not going sr ,would rather stick with an a series no matter how unreliable it is
Posted on: 2011/12/13 1:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
« 1 (2)
