A Series Manifold Templates For AutoCAD Available?
From SoCal
Hello all.
My name is Tom and I am a new member. I have been lurking for a while. I am planning an A15/5 speed build for my 1969 MG Midget and am making several plans for intake/carb combinations. I found the thread by member TnPshow A-Series Manifold Templates for Autocad - Come n get 'em. Just what I needed! Except the "members.iinet.net.au"-based links were all dead. Since TnPshow's member email is also from that ISP and since his member profile shows his last post being May of 2010 I don't hold out much hope that he will see this post.
What I am looking for is a copy of the CAD file for the intake and exhaust flanges for the small oval port H89 head. This head was OEM for 1980 A14s in the 210 and I snagged one recently to use on my 1982 A15 build. I plan to mod the factory intake to take a side draft carb of some sort (I have a 38mm Lectron) to get it running and broken in, then I will probably move to a twin HS4 deal. There may be other plans or options if I can just whittle parts out at will. Having the CAD models will make things much easier.
If anyone has the same or similar (later-style intake flange) intake and exhaust flange AutoCAD or Inventor (or DXF or STP) files could I get a copy? I have access to Inventor 11 and below.
On edit, eye candy:
Posted on: 2012/1/18 20:05
Edited by 58custom on 2012/1/18 20:45:06
Edited by 58custom on 2012/1/19 20:46:48
1969 MG Midget, A15/60A
Re: A Series Manifold Templates For AutoCAD Available?
From Las Vegas USA
First welcome,
You may or may not be aware that there is a twin carb set-up for the A-series engine, the GX manifold and twin hitachi SU's.
Getting that would save a lot of work. Now of course you may have a collection of SU's and manifolds in your MG stash and want to experiment. I would love to see the progress of your project, I've got a buddy who has a 68 Sprite he's working on, I tell him he needs to come and grab a Datsun engine from my garage. I do happen to have a an extra A-Series GX manifold lying around that I likely never use if it will help.
Tom in Vegas
Posted on: 2012/1/19 15:39
From Portugal
I have the dwg files of TnPshow .
Send an email to srpinho@hotmail.com
Posted on: 2012/1/19 20:18
datsun 120y / datsun 1600 sss
From SoCal
Thanks! PM sent.
Posted on: 2012/1/19 20:43
From SoCal
Thanks you! Email sent.Quote:
Posted on: 2012/1/19 20:44
As RallyTwit has mentioned twin sidedrafts are already available if need be but since you are using lectrons
which are like bike carbs you can splice a stock manifold
for the flange and weld the tubes to is you need and
reinforce bridges like on turbo manifolds using flat plate.
Posted on: 2012/1/19 22:27
From SoCal
Yes, I have been pondering more than one mod to the stock intake. In fact I have it on my list to get another one the next time I see it at the junkyard. But I also want to keep my options open in the future. I might try the 4 carb setup using bike carbs. I will eventually get around the EFI. I plan to have some fun with this engine and playing with carburation and induction is one good way to do that.
Here is one guy who modded the stock 210/310 intake to take two HS2s.
I plan to do the same but I will have to modify it to take flanges for HS4s.
Posted on: 2012/1/20 1:31
Edited by 58custom on 2012/1/20 1:56:08
From Las Vegas USA
Bike carbs for reference.
jpg  833_4c0875eb2fe7e-1.jpg (84.85 KB)
833_4f1a2c7da01ed.jpg 288X216 px
Posted on: 2012/1/21 3:09
you can also use the twin weber manifolds this way
http://datsun1200.com/modules/newbb/v ... id=384956#forumpost384956
Posted on: 2012/1/24 10:44
From Christchurch NZ
For anyone who is interested, the drawings can be downloaded here http://www.nzdatsun.com/forums/viewtopic.php?f=20&t=3276
However, you'll need to register 1st.
Posted on: 2012/2/2 21:00
Forced Induction!
