different angle...
This car had pretty wide track:
-S13 (CA brakes) front end which is the widest front end you can stuff in a 1200
-Corolla BW68 4.3 diff. About 3" wider than 1200/120Y diffs, but the memory might be a little fuzzy there. It increased track to match a Stanza front pretty much exactly.
-And 13x7 -7 Superlites with 205/60 tyres
obviously the rear needed to be lowered ALOT, so I taped the flare on lower for the pic coz it looked stupid sitting up high above the tyre. Its much more obvious from this angle. With the car lowered and the flare in the right position, it would look alot fatter. I just whacked them on to see how it would look.
And the fronts didn't quite fit under the flare, but the S13 setup is wider than the common strut swaps, so the neg offset wheels and big tyres didn't quite fit under the front. These wheels fit easy with Stanza struts on my coupe for instance. A different wheel like a 14x7 +0ish with a 185 or 195 would have been good for the S13 front. Or even just a 185 on that Superlite would have worked.
I reckon the flares and bobtail would have looked great on this painted black like the bumpers.
