Browsing this Thread:
1 Anonymous Users
h165 axels combined with ae86 diff |
From dominican republic
sooo been reading a lot of this topic and could collect some info. want to know if anyone has done this, will i have to do it?? well i will do it, my ae86 diff is shortened so will try the h165 axels on it because i have one ae86 broken axel they are very uncommon and expesive in here so will try it with 1200 ones, not right now but some day (near) does anyone has some more info to share??????????????
Last I checked, Pit Road carries the H165 part (LSD Nismo P/N 38420-RS110). See H165
Pitroad sells a brand new LSD for the H165B axle (1985-up Sunny Truck) for about $1200 USD. It is from TRD (Toyota Racing Development) and is a bolt in when using the AE86 ring gear bolts. Pitroad H165 LSD or TRD
You can also buy the AE86 LSD (PN 41301-TA005) direct from TRD, be aware however that this is untested, and probably won't fit most H165 carriers. About $850 USD
d_lsd1.jpg TRD Sales NZ
I do not like the conversion as you would need to machine down the bearing carriers so much to fit the Datsun bearing that there would be not enough metal left.
ill try it this way
(A better way is to get Datsun axel tubes welded to a sprinter diff centre housing. you would run a full TRD/Sprinter centre and gear ratios but still use H165 axels. getting the housing changed is also a easer job than modifying the centre.)
Posted on: 2012/2/17 4:17
Re: h165 axels combined with ae86 diff |
From melbourne
Try S W Motorsports- Tim 02 45 772 400. Toyota kaaz lsd about $1600+$500 for machining and fitted.
Posted on: 2012/2/17 8:33
From melbourne
Oh yeah, tried and tested No problems
Posted on: 2012/2/17 8:36
Hey mate, Can get someone or company who imports from japan in getting the following.Can use web translator to translate to english.That could be a start.... http://page5.auctions.yahoo.co.jp/jp/auction/e123222709
Posted on: 2012/2/17 8:50
im going to do it cause in my country (domican republic)its a little cheap to weld the housing and to get the h165 axels and housing and im very poor to buy a new lsd having one with just broken axel
hope the h165 axels do fit into the ae86 lsd diff
thanks nickmitty
Posted on: 2012/2/17 13:11
so... i got the 1200 housing and both axels, tested them in my ae86 shortened housing and lsd diff, they fit!!!!! also the ae86 bearings are bigger but i can use 1200 ones cause they have the same diameter outside the only problem is the shaft seal, it is not the same cause ae86 axels have bigger diameter, i have to figure out witch one will i use, will update on next weekend cause don't have time right now
cheers from Dominican Republic :)
Posted on: 2012/2/19 0:37
Registered Users Contentmaster Usermaster
Nice work!
AE86 came with a couple of different rear axle assemblies, which one are you working with? Year and model? T281 or T283?
Posted on: 2012/2/19 2:26
well DD, i don't know the answer to your questions but it is a trueno (jdm) or a GTS (usdm) factory lsd and disc brakes, the one that uses the big bearing and 4.30 final gear i bought it from a japanese used parts importer
Posted on: 2012/2/20 2:39
That's the good one, hard to find. Used like one year in USA. T284 I think.
Posted on: 2012/2/20 3:37
yep, very hard to find and the parts ugh!!! thats why im after the 1200 axels :P
i paid 200 pesos dominicanos for them thats like 5 us dollars :P
Posted on: 2012/2/20 15:09
Edited by mpower on 2012/2/20 16:20:52
