Browsing this Thread:
1 Anonymous Users
Which 2 liter, opinions - goal is 150 RWHP |
From Las Vegas USA
Here is the scoop. I have my A15 build up sorted (parts on they way) but this will bea semi mild build (110 RWHPish) This is the Mrs fault. I was sourcing parts and she noted that it wasn't likely to make enough power and said
" if this motor is still going to be under powered just put a motor in it that will make it fast"
The class I run at vintage is under 2 liter NA; So which motor? The 150 WHP mark was picked because this is equal power to weight ratio of cars I've driven that have a nice balance of power / handling. My initial thought is L-series would work being that full race L16s are close so a milder tuned L18 or L20B would likely get this done. Also want like to stick with Nissan. Other thoughts were crazy stroker big bore A-series 1800cc motor.................thoughts, opinions .02 or just plain silly ideas welcome.
Tom
Posted on: 2012/3/21 1:26
Re: Which 2 liter, opinions - goal is 150 RWHP |
From Melbourne AUS
150rwhp L series would be awesome for a race car in my opinion,
i have 150rwhp in my ute (rotary) and like you i think its a great amount of power for a 1200 on the racetrack,
but the extra torque of an L series would be great, especially to pull it through the high rpm in 4th/5th gear
Posted on: 2012/3/21 1:46
1973 B110 A12
L18 with some work but Pigdog had a exrally motor - hauled butt but only had 120hp at wheels.... Was more than enough fun
Posted on: 2012/3/21 2:25
From Wagga Wagga, NSW
SR20de. makes 140hp stock, buy a short motor, add webers and some poncams and you'll see 165hp easy.
Posted on: 2012/3/21 2:47
Ryan(Zigzag) says: mmmmm men
Jake(tuf-110) says: i thought you might say that
Ryan(Zigzag) says: its raining men
Jake(tuf-110) says: oh its your day
From Melbourne AUS
i think he runs in a vintage class? meanming modern engine's may be a no no
but im curious? which model sr20de makes 140rwhp?
or is that engine horsepower?
Posted on: 2012/3/21 3:13
1973 B110 A12
Engine horsepower.
I read that it was vintage too, but I think they will let it in seeing as it still uses a dizzy and if it was on carbs the only thing it would have over an l-series or "vintage" motor is that its twin cam.
S14 sr20de has VCT which packs a punch, but you eliminate that if you go for bigger cams.
Posted on: 2012/3/21 4:00
From Geelong, Vic
yeah my L series had some balls, but apparently much over 100rwkw from an NA 2 litre L series without too much serious work is a bit of an effort
mine could have probably got 130-140rwhp with a larger cam and making use of some more rpm. but it was built for torque mainly no peak power had plenty of torque but needed some better diff gears, needed something more like 4.3s or something rather than the 3.7s i was running to make it really good
Posted on: 2012/3/21 4:44
From Sydney
I'd use a k20a but a very expensive 2l motor put bike carbs on it if your not allowed injection but I'm not sure if the vtec would work without a computer so probably useless but if you can run a computer you'll be cheering
Posted on: 2012/3/21 4:48
From MOOROODUC. Victoria
If you're looking at an L series motor there is a good book on modifying them published by HPBooks
"How to Modify Your NISSAN/DATSUN OHC Engine" by Frank Honsowetz ISBN 0-89586-353-7 Library of Congress Number 85-81747
Well worth a read
Posted on: 2012/3/21 4:57
Red 1200 Coupe (Build: DEMAC's 1200 Coupe) Blue 1200 Ute, CA18DE Auto (Build: DEMAC's 1200 Ute) Green 1200 Sedan (Build: Kermit the beat up sedan) Green Sedan #2 (Current build: DEMAC's 1200 Sedan)
From Malaysia
as a user, i would recommend L series motor. bulletproof like an A, and much more torquey. plus, dogleg box is not so rare compared to A. at least for my side of pond.
Posted on: 2012/3/21 5:04
