(1) 2 3 4 »
NEED HELP!! A12 Engine
Not too shy to talk
From Pakistan Islamabad
Hello All, May Peace and Blessing be Upon You All :).. I am new here to this club... My Name is Nabeel and I am From Pakistan (and No I am Not a Terrorist :D), I happened to purchase a Nissan(Datsun) 1200 Coupe over a year now, There are only 2 Coupe's in my Country that i know of :D, and many Sedans, It has a Nissan 50th Anniversary Edition Badge on it... Will be posting Pictures soon.. The Car Was in a pretty Banged up state when i bought it, engine was Stock A12 and was about to retire... i rebuilt it a few months back, increased the Compression, and bored it to 1255cc.. the Fuel Tank was pretty Rusted out so i had to clean it and meanwhile ran the car on a 1Gallon Bottle :D... ran fine... after fixing back the Fuel Tank.. The Nightmares began... the engine would run fine on idle when i gave it gas it would bog down and die, and a lot of missfire, changed the coil, put and electric fuel pump, changed the fuel lines, breaker point in the dizzy, still the same, engines runs fine for like 20 15 min and then dies especially when under load or Acceleration... Any Suggestions would be Greatly Appreciated.. Thanks :)
jpg  1332586027_334004178_8-Nissan-1200-Coupe-.jpg (48.02 KB)
15291_4f8e387d7ce2e.jpg 625X469 px
gif  IMG0389A.gif (103.58 KB)
15291_4f8e3898459c6.gif 640X480 px
gif  IMG0395A.gif (53.47 KB)
15291_4f8e393ead358.gif 640X480 px
jpg  IMG0386A.jpg (50.50 KB)
15291_4f8e3a5b0f3ae.jpg 640X480 px
jpg  1332586027_334004178_3-Nissan-1200-Coupe-Islamabad.jpg (31.59 KB)
15291_4f8e3a863a10c.jpg 469X625 px
jpg  1332586027_334004178_6-Nissan-1200-Coupe-Islamabad-Capital-Territory.jpg (32.06 KB)
15291_4f8e3a91c9450.jpg 625X469 px
jpg  1332586027_334004178_5-Nissan-1200-Coupe-For-Sale.jpg (29.93 KB)
15291_4f8e3a9f1d434.jpg 469X625 px
jpg  IMG0398A.jpg (35.40 KB)
15291_4f8e3ab64b312.jpg 640X480 px
gif  1332586027_334004178_1-Nissan-1200-Coupe-e112.gif (126.87 KB)
15291_4f8e5e6489408.gif 625X469 px
jpg  IMG0402A.jpg (52.50 KB)
15291_4f8e5eb8b5bf2.jpg 640X480 px
Posted on: 2012/4/18 4:26
Edited by nabeel on 2012/4/18 4:45:30
Edited by nabeel on 2012/4/18 4:47:14
Edited by nabeel on 2012/4/18 4:47:51
Edited by nabeel on 2012/4/18 4:50:34
Edited by nabeel on 2012/4/18 4:52:02
Edited by nabeel on 2012/4/18 4:53:30
Edited by nabeel on 2012/4/18 7:27:04
Re: NEED HELP!! A12 Engine
From Ballarat Victoria
Hi Nabeel, Welcome to the club!
It sounds to me like there is some rust or scale in the carby from the tank. It is probably blocking the jets.You will have to pull the top off the carb to clean it out.
Are you running a good fuel filter before the carb?
Maybe put a filter before the pump aswell, especially if there is a chance that the tank isn`t rust free.
Keep up updated.
Cheers
Posted on: 2012/4/18 5:15
VIC DYNO HIRE
From Sydney
Welcome
Check all the simple things like plugs, leads, fuel filter, Dizzy cap and rotor button. Then I would do a compression test of the engine and check the fuel pressure.
Its possible that the carby could be full crap from rusty fuel tank.
Does it run hot?
Posted on: 2012/4/18 5:18
Not too shy to talk
@sikyne, Thank You brother, as a matter of fact there was rust in the carb, cleaned it out twice, i am running a good fuel filter and it is placed before the fuel pump, not the carb... should i put one before the carb too? no rust or dirt coming in so far.. @Gav, checking plugs right now, dizzy cap is fine also fuel filter and rotor button, and fuel pressure is Awesome :), does what run hot? sorry didnt get you there.. Also i forgot to mention when i crank the engine it would suddenly jam then crank then jam real bad... the local mechanics say it is a timing issue... I have tried retarding and advancing the timing but its the samething... also there is no vacuum connected to the carb except the vacuum advancer, because i am running a performance filter...
Posted on: 2012/4/18 5:38
Not too shy to talk
and the battery seems to be dying to early, alternator is excellent, the coil heats up but there is spark, the Ignition coil is from a Nissan Pulsar not the standard oil based coil but a dry coil
Posted on: 2012/4/18 5:41
Have you checked the points, and dwell angle? if this is way off it can cause misfires and rough running. If you have a dwell meter, set the dwell angle to between 48 and 52. At least check the surfaces of the contacter faces. Make sure they are not too pitted. Im not sure what the points gap should be if you dont have a meter. Maybe about .5mm-.7mm? Someone else here will know the right gap setting.
Once the points are set. the timing will have to be redone.
Posted on: 2012/4/18 6:05
VIC DYNO HIRE
From melbourne
Welcome.
Posted on: 2012/4/18 6:17
Quite a regular
hey mate, as above these should help you out, are they r32 gts-t tailights moulded into the back of it? i have never een that before.
cheers
Posted on: 2012/4/18 6:37
Not too shy to talk
@sikyne, Bro the points are really low quality made in China, dont have a dwell meter, will have have to look into that as that is my only hope, didnt no the timing has to be redone, will do that too.. keep you updated thanks alot brother, can the distributor cause the coil to heat up??, and cant figure out why the engine dies when i floor it... Idles just fine, like too much air or too less petrol... will post a pic of the carburetor please dont mind the bad quality picture, dont have my camera with me have to do with this... @nickmitty.. Thanks Bro... @4slips, Yes Bro, they are R32 Gts-t Tail Lights, they would look better... :)
jpg  IMG0013B.jpg (46.65 KB)
15291_4f8e5dd7dd764.jpg 640X480 px
jpg  IMG0015B.jpg (42.23 KB)
15291_4f8e5dfc6a7b9.jpg 640X480 px
Posted on: 2012/4/18 7:22
If the points gap is too narrow, the coil will run a bit hotter. Yes, the timing has to be reset after the points are set.
Posted on: 2012/4/18 8:04
VIC DYNO HIRE
(1) 2 3 4 »
