Dry or Drive shaft option
From Trinidad W.I.
My dry/drive shaft is gone and I need a replacement. I'm using an A15 engine and a 4 speed gear box. Is there any other dry/drive shaft besides the original that I can use to replace mine?
Posted on: 2004/3/24 4:46
Re: Dry or Drive shaft option
From Perth W.A
Whats happened to it?
if it's just the uni joints then just get them replaced, won't cost much more than 150 for new uni's and balancing.
Posted on: 2004/3/24 5:07
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Trinidad W.I.
Nah its worst than that, its warped meaning that its not straight anymore, when I reach like 50 miles it start to vibrate and make noise. I'm concerned that it may damage my gearbox or differential or even the engine, thats why I need a new one or any other one that could replace it.
Posted on: 2004/3/25 5:09
From Castro Valley,CA USA
It cost me $100 for staightening, balancing and u-joint replacement on my drive shaft.
Unless it's wrapped up like a pretzel, you might still be able to fix it.
Posted on: 2004/3/25 5:44
From Canberra
If it is bent then it can be straightened and re ballanced. If it is twisted then throw it in the trash because there is nothing you can do about it.
Posted on: 2004/3/25 5:59
From Trinidad W.I.
Exactly that its twisted, and a dry shaft is very hard to get in Trinidad. Is there any other dry shaft from another car that can work?
Posted on: 2004/3/27 5:16
From Christchurch NZ
You could cut the yolks off , and weld them onto a new tube.
Posted on: 2004/3/27 6:32
Forced Induction!
From Auckland, New Zealand
Hey A14force thats a good call! We did that to a demo derby car a year ago - I know obviously this a different application, but i have heard of people doing this for road use to, once you have proper balancing etc..
Posted on: 2004/3/27 12:01
#Datopower#
From Coondle, WA Australia
Hey team dat..
for $150 you reckon that you can get your propshaft rebalanced and new uni joints. That makes it like new yeah??
Have slight vibration problems in Daisy, but havent really looked into it as I was expecting a large bill to get it done.
any good shops that you reccommend in the eastern end of perth prefrebally??
Posted on: 2004/3/29 0:01
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
