(1) 2 3 4 »
Tips For Shortening R31 Diff
From A.C.T
Hey guys wat i would like to know is a few tips for shortenign an r31 diff? i plan to pay someone with skill to do it but i wanna save as much as i can. so after cheking out pics of other diffs i was thinkin mayb first i should cut all of the old taps and parts on it that are used for fitting to a skyline. ?
Posted on: 2012/6/1 12:41
Re: Tips For Shortening R31 Diff
From South east vic
Yep clean all mounts off, and get them to shorten long tube to small axel size and then shorten and respline long axel to new length!
Then this way u only need to shorten and spline one axel
Posted on: 2012/6/1 12:59
1200 coupe under construction
From A.C.T
So if yu do that will the diff still be centered? how much need to be choped off? its going into a 1200 ute?
Posted on: 2012/6/1 13:05
From Narellan,Sydney
Depends on what wheels,offset you have to work out diff length
Posted on: 2012/6/2 0:55
From penrith,sydney,aus
the diff wont be centered, normally the diff is offset abit to the drivers side, but in doing it the way supa said it offsets it to the passenger side
its the cheapest way to do it and its fine
Posted on: 2012/6/2 11:23
2 door 1200 sedan project l20b stroker
From A.C.T
i might have to do that then< is it cheaper / smarter to get the axle cut and re,splined or to jst get custom axles?
Posted on: 2012/6/3 11:36
From Sydney
Just give the car and diff to a shop and tell him what you want and they'll measure it all up etc. 1. Less #OOPS#ing around
2. 99% chance of a near perfect fit
3.warranty
4. Easier
5. More chance of it being done properly the first time instead of u missing something/ or not doing something right.
Pay a lil extra for a proper job
Posted on: 2012/6/3 11:58
From A.C.T
yer tru, but out of all the quotes ive had, none have been below 1600
Posted on: 2012/6/3 12:12
From windsor, sydney
you should look through the previous threads on this subject and realize that it sounds like you don't know what you want yet. there are some important pieces of information you need before you even start, firstly what wheels/tyres are you using? 2)what brakes do you want? 3) 4 or 5 stud? You mentioned custom axles, there is $600-$700 just there. to cut and shorten then respline an axle is $150-$180 each , cut and shorten a housing then re straighten it after it is welded is $300-$400 depending on the donor housing ,are you going to supply the donor housing and axles /brakes or do you expect the shop/ fabricator to source that too , and what about the gear ratio and hemisphere what ratio do you want? do you want a LSD? do you expect it to be reco'd?
$1600 might sound up there but if you want a profesional job done that's what it takes. I can already hear the winging and belly aching when it fails because you want to short cut the process. Here is a pic of a 9inch housing i built for a drag car housing alone cost $1000
jpg  30062011451.jpg (65.51 KB)
9512_4fcb590416d83.jpg 640X480 px
Posted on: 2012/6/3 13:23
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Melbourne, Australia
thanks wards, was looking to get my h190 shortened (already mounted in car, now i have a rough idea how much
Posted on: 2012/6/3 13:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
(1) 2 3 4 »
