Browsing this Thread:   3 Anonymous Users
Spark plug colour
What does it indicate?
#2 and #3 plugs are tan all around
#1 and #4 plugs are white on the half next to the gap
Posted on: 2012/6/11 7:00
Re: Spark plug colour
From RAdelaide
white is overheated - lean fuel mix or to much advance on ignition timing?
2 and 3 would seem normal
Posted on: 2012/6/11 7:09
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
White is correct. But in this case, they are perfect tan over one-half the insulator.
Timing is 10 degree BTDC, very conservative.
Carburetor is stock Datsun 1200 carburetor.
Posted on: 2012/6/11 7:13
From Malaysia
i think the plugs are 1 heat range too hot? perhaps you could go 1 range colder. the AFR looks a little lean though.
Posted on: 2012/6/11 8:38
But two plugs are perfect color. Will not richening the AFR make them too rich?
Posted on: 2012/6/11 8:48
From Malaysia
if it is my engine, i would change the plug 1 range colder, and drive it for a while. after a while, open the plug and see if the ratio is good or lean. my previous experience, if i were using 1 heat range too hot, the plug reading shows the mixture a little too lean, but everything else is perfect. drivability, cold start (in malaysia where everyday is summer).
have you done compression test?
Posted on: 2012/6/11 8:59
Yes, compression is good. Plugs show no sign of running lean -- every plug is a nice tan colour. They don't look hot to me, no overheating or blistering is evident. The plugs that are part white are also part Tan! Look at the photos carefully to see what I mean.
Apparently this half/half plug condition is not uncommon. Searching, I see it is reported from Nissan to Chevrolet and from chain saws to snowmobiles. No one seems to know what is is, but people are guessing at the cause -- all different sorts of guesses.
Posted on: 2012/6/11 9:23
From south coast nsw
yeah they look pretty good,my plugs in my daily kept doing that but worse ,almost sure its a bi product of all the burnt fuel additives.
Posted on: 2012/6/11 9:56
From Newcastle nsw
and use denso or ngk plugs. there better than most. Champion make good mower plugs but thats it. ive had several dead out of the box (platinum and iridium included)
refuse to use them in customers cars these days.
Posted on: 2012/6/11 10:56
I agree they`re running well but I prefer Jp plugs in Jp donks
what was your economy by the end?
Posted on: 2012/6/11 11:54
