carby / manifold idea
From Fremantle, West Australia
was looking a box of carby bits and had an idea!
I know more about brain surgery than carbys.
If you look at an H95 inlet manifold (ex B310 A15) the side where the PCV screws in is flat sided..
Using a simple lump of 16mm ally plate as an adaptor, I think a single SU carby could be fitted to the SIDE of the H95 manifold.Original carby opening would have to be blanked.
probably not enough room between the head and strut tower for this on a 1200 but it might fit on a 1000
Would this work or is this a BAD idea?
Posted on: 2012/6/26 11:39
Re: carby / manifold idea
From Sydney
Sounds like a good idea, I wonder how well a A15 will perform with a 2 inch SU
Posted on: 2012/6/26 11:47
Brilliant idea! We'll have to see how well it works.
A single 38mm throttle should work well with a plenum manifold (like the stock manifold). The stock carburetor is only 20/26 venturis, the 38mm sidedraft opens up to almost a 38mm venturi.
The twin-configuration has no plenum to speak of so each 38 only works part of the time. With a plenum it's working full time so to speak.
Posted on: 2012/6/26 11:56
most of my toys are in storage
could someome using an H95 inlet on a B10 or B110 measure the distance between the PCV and the strut tower?
Posted on: 2012/6/26 12:08
From Perth WA AUS
Good thinking there Mal :)
Posted on: 2012/6/26 12:13
Datsun 1200 2Dr sedan.
can be made much prettier but heaps of suzuki 4 x 4 peeps use them
http://www.shropshire-suzuki.co.uk/fo ... .php?f=13&t=2625&start=15
sound pretty good too!
http://www.youtube.com/watch?v=Ga03Ic564vA
maybe you can fit one of these also :)
http://classicmotorsports.net/media/i ... alse&height=400&width=700
have a look at the safety blow off or backfire valve!! classic
Posted on: 2012/6/26 12:14
the sierra 90 degree bend set up is plan "B" if grafting to the side is not possible
Posted on: 2012/6/26 12:25
i was thinking of a similar thing with my new plenum after alloy welder fell through. seeing one tomorrow but i also have a spare su manifold.
if i could mate the two for log- win. will put in build thread not clog up here
Posted on: 2012/6/26 12:27
