« 1 2 3 (4)
Re: SHED CLEANOUT ! perth ,must go !
From Perth WA AUS
+2 for previous dealings with Jesse that I am happy with.
He is a nice guy.
Posted on: 2012/8/9 10:54
Datsun 1200 2Dr sedan.
From mandurah
hey jmac ,ill pm you but im happy with $300 for the lot ill give you all my coupe lights cos they are no use to me ,so youd have enough lenses to make a set and have spares
im about 45 minutes from those depos but i could probly get a pallet send up to the depo and sent from there as its hard to take time off work
ill throw in the coupe rear wedge shaped lights and trims aswell if you want them?
havnt posted anything large before but ill ring around to morrow and see what i needa do to get it sent up to the fremantle depo
as for the carby parts ,it was the 2 covers hat go in between the throats on the back side ,they cover the thorttle pump linkages ,the 4 screws and a spring that does something special (dunno what it does)
as far as i knew it was all there ,never played with webers so i didnt notice ,and just now D has mentions there was apparently a float missing and jets missing ,i had the tops off and both foats were in them aswell as all the jets as i checked them for sand and stuff ,just to make sure it wasnt something simple that was making them run rough
i put a battery on charge tonight so it should be nready to do a comp test on the a12 dale :D
got 2 late a12s ,one i cant sell with the numbers on it as its the original motor for my ute and would like to keep the numbers ,the other is as being held for dale (rooster) but if your after an a12 i can find you one ,mike (dundee1000) has aroung 20 a series motors in his shed (freakin crazy i know!) and he would sell you one
no oval port heads ,best bet would be mike again ,he is awesome to deal with ,bought my a15 block off him and all my bprojects stuff aswell as carbs ,and everything inbetween ,top bloke
thanks Nige!
ill reply to all pms !
Posted on: 2012/8/9 16:25
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
also had a call from a guy names jack ,said he was from the forum
if you want i can ring you back about the ute shell ? just pm me your number and ill ring you when im free
cheers
Posted on: 2012/8/9 17:21
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Albany, Perth Australia
after many years with dealing with jesse i have never had a problem. He has always been helpful and willing to lend a hand when needed. Jesse's character has never been under question but for you D i cant say as i have never dealt with you. I think what you wrote should be taken off and take to to pm's as it really is uncalled for. But that's my 2 cents worth
Posted on: 2012/8/11 14:06
1200 Smerf Mobile
From mandurah
a14 flywheel sold and ute leafs springs aswell
bump! still got heaps of stuff
Posted on: 2012/8/19 14:20
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Wanneroo, Western Australia
Apologies to your Pops for holding you both up by dribblin' Datto mate.
Posted on: 2012/8/19 14:29
From mandurah
haha nah he went inside and fell asleep as soon as he got home ,all good ,hope the springs and stuff stuff work in your thou ,should stiffen it up abit!
Posted on: 2012/8/19 14:46
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Not sure if you got my pm reply about the parts? No worries I'll re-send if it didn't make it!
Posted on: 2012/8/22 10:37
John McKenzie
From mandurah
pm replyed jmac :D
Posted on: 2012/8/22 13:06
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth, Western Australia.
Hey mate Just sent you a text, I will def grab the coupe shell if you still have it. Can pick it up tomorrow
Posted on: 2012/8/24 2:08
71 Coupe
KE70 ca18 drifter
« 1 2 3 (4)
