« 1 ... 53 54 55 (56) 57 58 59 ... 67 »
Re: pigdogs CA 1200 wagon
Great stuff. Feels good knowing no hassles really if you get pulled over . Sort your insurance too.
Posted on: 2012/8/10 2:40
Well done Piggy one of the rare few BRG datsuns on the road
decided on carpet yet? tan looks good with BRG otherwise
although black is dirty its easy to just spray with black
acrylic paint once in a while after vacuum comes up new.
Posted on: 2012/8/10 3:23
Edited by D on 2012/8/10 4:21:41
From Geelong, Vic
Ordered the carpet ages ago. Should call the idiots and see whats happening with it. They took my money a week or 2 ago
anyway. Put the locker back in and the new rear wheel bearings. So i now have proper ball bearing wheel bearings that shouldnt just cruise all over the place
with the locker back in, instantly 100% more fun to drive
Posted on: 2012/8/10 12:21
ITs common these days, you spend money then you have to chase for your purchase when it doesnt arrive. Customer service is not what it used to be anywhere anymore.
Just wondering what happened to your h190 alloy centred setup?
Posted on: 2012/8/11 2:52
From Geelong, Vic
still got the alloy centre, never got around to finding a bluebird or gazelle diff to cut down. so for the moment the centre is just sitting in around in storage
Posted on: 2012/8/11 13:59
From Geelong, Vic
so onto pics of the progress since engineers
So this is what it currently looks like
And what room i have available, standard shock crossmember removed
Like so
New fuel tank, shorter and narrower, new crossmember will be 50mm further back so the tank needs to be shorter, and it narrower to give plenty of room for the rear muffler
Measures around 600x520x200 and will hold about 60ltrs
Baffling and swirl pot inside the tank
side view
starting the new rear crossmember, how the coilovers will sit
top coilover mount, formerly a stanza shock rod
Bracing up the section of the crossmember that the mounts go through
Main bar is 75x50x2.5 rhs. brace plates are 3mm thick
more progress on the tank, might notice that it warps pretty easy which is a little unfortunate for its looks...but #OOPS# happens
so the other wagon i'm using to mock stuff up only has a half leaf in one side to give room for the coilover to sit behind the diff, so to keep it at the right high there's just a block of wood between the diff and the chassis
so anyway, jacked the car up to move it across a bit, jacked it up off the towbar
bit of wood fell out and i thought the car looked a little funny when it got stuck on the jack
Posted on: 2012/8/11 15:29
Now that's one low wags! Good looking mods there nick
Posted on: 2012/8/11 16:01
Car free
From Geelong, Vic
ALso replaced the crappy tapered roller rear wheel bearings with some ballbeaaring units. have had nothing but issues with the rear wheel bearings in this diff constantly having pay in them, even from new have 1-2mm of movement in them which with the r32 rear brakes caused the caliper pistons to be pushed apart and gives longer than normal brake pedal travel, or you pump the brakes and they come up to how they should on the second pump
basically from what i can see its just a #OOPS# setup to start with
so heres the new bearing, bearing and seal are one complete unit
and the standard setup
all ready to go
trying to figure out what bushes to run for the rear control arms
its going to be a 3 link setup, so 2 control arms and a panhard rod
the 2 control arms will look kinda like this
so they will each have 2 mounts on the diff and the front mount will go to the standard leaf mount position
going to have the main red arm and then the green arm will bolt to it
both arms will be adjustable so that the red arms control the diff location and the green arms will be able to adjust the pinion angle
so back to trying to figure out the bushes, at the moment im thinking the red arms will have rubber bushes and the green will use rod ends, mainly because both mounts on the green arms will need to be fairly small to both fit onto the red arm and to fit on the top of the diff without fitting the floor/coilovers/exhaust, they wont actually be moving during operation so them wearing out shouldn't be an issue
so the mounts in the red arms will be taking all the movement/forces from the diff, mainly thinking about the forces during acceleration. so i figure as they are the only rubber parts that should be fairly strong
the 3 mounts ive been looking at, coz they were sitting around at dads are in the pic below
top is an r31 rear upper control arm, measures 60mmx54mm diameter
middle is an 80 series landcruiser rear control arm mount, 60x55
bottom is gq patrol, not sure which arm exactly, its 50mmx60mm
r31 mount would be ideal as i have the control arm so i can use its ends to make up my new control arms, only issue i have with it is that the rubber only connects to the outer section by a 15mm strip around its diameter
so i'm not really that confident in using them when they only have such a small conection in the bush
the patrol one would be my next choice as the whole bush is solid rubber and would be more than strong enough, so im trying to chase up some patrol arms at the moment.
so ill see how i go with that, got plenty of mates with gqs but most have gotten rid of their spare or standard arms
was going to run a rubber bush on the diff end of the green arm also, but figure it will be be easier to use rod ends as then i just need a tube with left and right hand threads in it to make it adjustable
got some pics of the fuel tank and rear crossmember in the other car also. just got the mounts tacked on, going to use the standard rear tank mount in reverse, tank will bolt to the bottom of it rather than sitting ontop of it like the standard tank
and will just have some mounts welded to the back of the crossmember for the front of the tank
will probably be welding the crossmember into my actual wagon tomorrow and getting the fuel tank in
so will be cutting the standard crossmember out, cutting the fuel pump flange out of the current tank and welding it into the new one, finishing off the bracing for the chassis area where the crossmember will be welded on, remake the rear section of the exhaust so it will clear the coilovers, brace the rear fuel tank mounts
have all day tomorrow to do it, so if i start early enough i might stand a chance of driving it home tomorrow night
plan at the moment is to get the crossmember and tank in, then drive it around with the leaves still in it till the front mounts are built, will be making them so the leaves can still be bolted in, will have to just run some spacers to get the extra width with the control arm bushes
then i should be able to make up the panhard and mounts and get them in with the leaves still there
and finally make up the control arms, control arm diff mounts and diff end coilover mounts and get them all in in one go, so all up shouldnt have the car off the road for more than a couple of days
should be able to keep driving with the leaves till i have to cut the mounts off the diff
Posted on: 2012/8/11 16:30
From Trinidad and tobago
Great Work Mate...I like it
Would Coilovers make it ride softer?Handle nicely?
Posted on: 2012/8/12 6:07
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Hmmm ... ball bearings are a lot weaker than roller bearings. And they do not handle side loads like the taper bearings do.
You should have figured out WHY they were going bad. It's usually do to overtightening (they should be almost finger tight, like 12 inch lbs or something like that). Or possibly a bent housing. Or improper shimming.
Posted on: 2012/8/12 6:30
