electronic speedo sender
Quite a regular
From Gold Coast
hey is it possible to change the speedo sender to a hall effect sender instead of cable much appreciated.
Posted on: 2012/7/21 10:20
Re: electronic speedo sender
Yes it is possible.
Posted on: 2012/7/21 18:29
Quite a regular
From Gold Coast
any ideas how
Posted on: 2012/8/18 9:12
From Brisbane, QLD
Online
im in the same boat, i gotta r33 cluster installed and i need a hall effect sensor. how do you install?
Posted on: 2012/8/18 9:43
76 B120 - Parted out in 2015 and gone to a better place
91 GB122 - Sold in 2017 to a kid doin' a resto on it
71 B110 - Almost RIP, long road ahead
From Sydney, Australia
Most ca18 guys use older gearbox drives in their newer s13 boxes, to convert from electric to mechanical speedo. Assuming the gearbox sender suits the dash cluster, that should work. Depends what gearbox you want to add the electonic speedo drive to.
Posted on: 2012/8/18 13:07
From Brisbane, QLD
Online
i need an electronic sender for a 4-spd 56 series transmission. anyone know where i can get one?
Posted on: 2012/8/24 9:24
From Geelong, Vic
Standard r31 speedo sender just screws into a normal mechanicl speedo drive. So one of them would do the job with pretty much any mechanical nissan speedo drive.
Bit surprising other nissans done use the same thing
Posted on: 2012/8/25 8:26
From Brisbane, QLD
Online
so if i just go and get a r31 electronic speedo unit, screw it into the transmission, the the other end should just plug straight into my r33 speedo?
Posted on: 2012/8/25 10:02
